SmartFTP Library VB error 17
bmangold
Post by bmangold » Wed Jul 06, 2005 8:02 pm
I have purchased and installed the license but am still receiving errors when attempting to connect via VB. The code I am using is below. It worked fine last week, before the free-trial expired.
    'Early Binding "Dual Interface"
    'Note: Force the compiler to use the dual interface if available
    Set objFTP = CreateObject("sfFTPLib.FTPConnection")
    'Early Binding "Mid Level"
    'Note: The compiler may use the dual interface
    'Set objFTP = New sfFTPLib.FTPConnection
    objFTP.Host = "xx.xx.xx.xx"
    objFTP.Port = 21
    objFTP.Protocol = ftpProtocolNormal 'ftpProtocolSSLExplicit
    objFTP.Username = "xxxxx"
    objFTP.Password = "xxxxx"
    objFTP.Passive = True
    objFTP.LogFile = pwd & "ftp.log"
    If objFTP.Connect = sfFTPLib.enumError.ftpErrorSuccess Then
        MsgBox ("Connected to " & objFTP.Host)
        If objFTP.ChangeDirectory("/xxxxx") = sfFTPLib.enumError.ftpErrorSuccess Then
            MsgBox ("ChangeDirectory() successful. (" & objFTP.WorkingDirectory & ")")
            ' Upload File
            Dim nRestart
            nRestart = 0
            Dim strMsg
            If objFTP.UploadFile32(pwd & "xxxxx.xml", "xxxxx.xml", nRestart) = sfFTPLib.enumError.ftpErrorSuccess Then
                strMsg = "UploadFile32() successful." & vbCrLf
                strMsg = strMsg & "LastTransferBytes = " & objFTP.LastTransferBytes32 & " B" & vbCrLf
                strMsg = strMsg & "LastTransferTime = " & objFTP.LastTransferTime & " s" & vbCrLf
                strMsg = strMsg & "LastTransferSpeed = " & objFTP.LastTransferSpeed & " B/s"
                MsgBox (strMsg)
            Else
                strMsg = "UploadFile32() failed. LastError = " & objFTP.LastError & vbCrLf
                strMsg = strMsg & "LastReplyCode = " & objFTP.LastReplyCode & vbCrLf
                strMsg = strMsg & "LastReply = " & objFTP.LastReply & vbCrLf
                MsgBox (strMsg)
            End If
            ' Read Directory
            If objFTP.ReadDirectory() = sfFTPLib.enumError.ftpErrorSuccess Then
                Dim objDirectory As sfFTPLib.FTPDirectory
                Set objDirectory = objFTP.Directory
                Dim objItem As sfFTPLib.FTPItem
                Dim strList
                For Each objItem In objDirectory
                    strList = strList & "Type=" & objItem.Type & "; Name=" & objItem.Name & "; Size=" & objItem.Size32 & "; Date=" & Format(objItem.Date, "MM/DD/YYYY HH:NN:SS") & vbCrLf
                Next
                MsgBox (strList)
            Else
                MsgBox ("ReadDirectory() failed. LastError = " & objFTP.LastError)
            End If
        Else
            MsgBox ("ChangeDirectory() failed. LastError = " & objFTP.LastError)
        End If
    Else
        MsgBox ("Connect() failed. LastError = " & objFTP.LastError)
    End If
Re: SmartFTP Library VB error 17
Post by mb » Wed Jul 06, 2005 10:09 pm
You need to call LoadLicenseKeyFile or LoadLicenseKeyData to load your license key.
bmangold
Post by bmangold » Wed Jul 06, 2005 10:12 pm
What should the argument be, I couldn't find a good example online.
-Bob
Post by mb » Wed Jul 06, 2005 11:41 pm
Please see the help file. Its the sfFTPLib.chm. You should also find a few examples in the SamplesScript directory.
'// LoadLicenseKeyData v1.0 (9. May 2005)
'// Purpose:
'//   Shows how to load the license key from a string.
'// Copyright (c) 2005 by SmartFTP.com
Dim strKey
strKey = strKey & "-----BEGIN KEY-----" & vbCrLf
strKey = strKey & "Product: SmartFTP FTP Library" & vbCrLf
strKey = strKey & "ID: 400000000" & vbCrLf
strKey = strKey & "User: user" & vbCrLf
strKey = strKey & "Company: my company" & vbCrLf
strKey = strKey & "Email: user@host.com" & vbCrLf
strKey = strKey & "Version: 1.0" & vbCrLf
strKey = strKey & "Number of Users: 1" & vbCrLf
strKey = strKey & "Date of Issue: 2005-04-05" & vbCrLf
strKey = strKey & "Maintenance Expiration: 2006-04-05" & vbCrLf
strKey = strKey & "-----BEGIN SIGNATURE-----" & vbCrLf
strKey = strKey & "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" & vbCrLf
strKey = strKey & "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx==" & vbCrLf
strKey = strKey & "-----END SIGNATURE-----" & vbCrLf
Dim obj
Set obj = CreateObject("sfFTPLib.FTPConnection")
WScript.Echo "Object created." & vbCrLf
WScript.Echo strKey
If obj.LoadLicenseKeyData(strKey) Then
	WScript.Echo "Success"
Else
	WScript.Echo "Failed"
End If
