Hide the password in the log file
rubensola
Post by rubensola » Wed Apr 20, 2005 10:13 am
Hi.
I want to use the log file but to hide just the line where it's showed
the password at logging. Is this possible?. I yet know that I can do it by coding after the transfering but it's not 'well' for me.
Re: Hide the password in the log file
Post by mb » Tue May 03, 2005 12:36 pm
Hello.
If you refer to the .LogFile then it's a good suggestion. Thanks :-) Hiding the password in the string provided by the OnStatus() event is the responsability of the application though.
It will be implemented in the next build.
Post by mb » Wed May 04, 2005 7:37 am
Implemented in the .19 build. Use the HidePassword property. It's set to false by default.
