SOLVED - VB6 OnTransferProgress
Gambit
Post by Gambit » Tue Apr 19, 2005 9:59 pm
I was wondering how to use the OnTransferProgress in VB6
What I would like to do is get the current size of the file that is being uploaded and also how much time is left till it's done being uploaded.
Is this possible?
Thanks!
Gambit
Re: SOLVED - VB6 OnTransferProgress
Post by Gambit » Thu May 05, 2005 10:38 pm
I've tryied this but I get nothing.
Private Function objFTP_OnTransferProgress32(nBytesTransferred As Byte)
    Label1.Caption = nBytesTransferred
End Function
Am I way off here?
Gambit
Post by Gambit » Fri May 06, 2005 5:46 pm
OK I figured it out
Just in case there are other newbies out there like me when it comes to dll and not ocx's
Put this in the declarations:
Dim WithEvents objFTP As FTPConnection
then on form load:
Set objFTP = New FTPConnection
You will now have all the functions for objFTP
Private Sub objFTP_OnTransferProgress32(ByVal nBytesTransferred As Long)
End Sub
Hope this helps some other people
EDIT:::
One question more question I have, is there any way to estimate the time the file has to upload or download. If there was a TransferSpeed on the OnTransferProgress32 we could just do a little math to figure it out. Unless there is a better way
Post by mb » Sat May 07, 2005 1:20 am
Regarding the time left.
Before you start the transfer. Save the following values:
- TransferStartTime
- StartPosition in bytes (>0 if you resume)
- FileSize in bytes.
then you can do the following calculation on every OnTransferProgressEvent
Speed = nBytesTransferred / (NowTime - TransferStartTime)
BytesLeft = FileSize - StartPosition - nBytesTransferred
TimeLeft = BytesLeft / Speed
Gambit
Post by Gambit » Thu May 26, 2005 4:22 pm
HELP NEW PROBLEM!!!!
If I do this route:
then on form load:
when I run my app in VB everything runs fine. After I compile the exe and I run my app as soon as the smartftp gets called my exe crashes on me. If I comment out the above code and put this back in
Public objFTP As sfFTPLib.FTPConnection
everything is fine but now again I don't have the OnTransferProgressEvent
is this a bug or am I doing something wrong.
If I can get this to work we are going ot make this dll purchase...one of hte best ftp.dll for vb I found!
Post by mb » Thu May 26, 2005 5:13 pm
What version of the dll did you test with?
Does it work with a version you previously tested?
Can you make a small sample applications to reproduce the problem and post the source?
Does it crash when the event is fired or when the FTPConnection object is created? In the first case I think we have the problem described in this article:
http://www.mvps.org/vcfaq/com/1.htm
Gambit
Post by Gambit » Thu May 26, 2005 6:33 pm
Looks like it happens when the event is fired.
Here is the code. I edited your demo
I get this error with using 1.0.1.20 (first one I started using) till the newest version.
with the the link you sent is this somthing I will have to do on my end or do you need to change something in the dll?
If it's something I need to do I'll have to spend a while trying to figure it out. This still is a little new to me. I'm used to working with ocx and not to many dll's
Thanks for responding so quickly
'Method used in demo
'Public objFTP As sfFTPLib.FTPConnection
'method used by me
'This works inside VB but once compiled to an exe causes a crash
Private Sub Form_Load()
'method used by me
' VB6 binding howto
    ' http://kandkconsulting.tripod.com/VB/Tutorials/vb_binding_tutorial.htm
    'Early Binding "Dual Interface"
    'Note: Force the compiler to use the dual interface if available
    Set objFTP = CreateObject("sfFTPLib.FTPConnection")
    'Early Binding "Mid Level"
    'Note: The compiler may use the dual interface
    'Set objFTP = New sfFTPLib.FTPConnection
    objFTP.Host = "ftp.smartftp.com"
    objFTP.Port = 21
    objFTP.Protocol = ftpProtocolNormal
    objFTP.Username = "anonymous"
    objFTP.Password = "test@test.com"
    objFTP.Passive = True
    objFTP.LogFile = "VB6Demo.log"
    If objFTP.Connect = sfFTPLib.enumError.ftpErrorSuccess Then
        MsgBox ("Connected.")
        If objFTP.ChangeDirectory("/SmartFTP") = sfFTPLib.enumError.ftpErrorSuccess Then
            MsgBox ("ChangeDirectory() successful.")
            ' Read Directory
            If objFTP.ReadDirectory() = sfFTPLib.enumError.ftpErrorSuccess Then
                MsgBox ("ReadDirectory() successful.")
                Dim objDirectory As sfFTPLib.FTPDirectory
                Set objDirectory = objFTP.Directory
                Dim objItem As sfFTPLib.FTPItem
                Dim strList
                For Each objItem In objDirectory
                    strList = strList & "Type=" & objItem.Type & "; Name=" & objItem.Name & "; Size=" & objItem.Size32 & vbCrLf
                Next
                MsgBox (strList)
            Else
                MsgBox ("ReadDirectory() failed. LastError = " & objFTP.LastError)
            End If
            ' Download File
            Dim nRestart
            nRestart = 0
            Dim strMsg
            If objFTP.DownloadFile32("History.txt", "History.txt", nRestart) = sfFTPLib.enumError.ftpErrorSuccess Then
                strMsg = "DownloadFile() successful." & vbCrLf
                strMsg = strMsg & "LastTransferBytes = " & objFTP.LastTransferBytes32 & " B" & vbCrLf
                strMsg = strMsg & "LastTransferTime = " & objFTP.LastTransferTime & " s" & vbCrLf
                strMsg = strMsg & "LastTransferSpeed = " & objFTP.LastTransferSpeed & " B/s"
                MsgBox (strMsg)
            Else
                strMsg = "DownloadFile() failed. LastError = " & objFTP.LastError & vbCrLf
                strMsg = strMsg & "LastReplyCode = " & objFTP.LastReplyCode & vbCrLf
                strMsg = strMsg & "LastReply = " & objFTP.LastReply & vbCrLf
                MsgBox (strMsg)
            End If
        Else
            MsgBox ("ChangeDirectory() failed. LastError = " & objFTP.LastError)
        End If
    Else
        MsgBox ("Connect() failed. LastError = " & objFTP.LastError)
    End If
End Sub
End Sub
Post by mb » Thu May 26, 2005 6:39 pm
Problem should be fixed in latest build 1.0.1.27. Please give it a try.
Gambit
Post by Gambit » Thu May 26, 2005 7:20 pm
I installed the lastest 1.27 and I still have the same problem.
I'll uninstall and reboot and install again to make sure
Update...uninstalling and rebooting didn't fix the prob. I still get the same error after I compile the exe
Post by mb » Fri May 27, 2005 6:27 am
Please try the new .28 build. The same approach has been used but with a different implementation.
