SmartFTP 1.0.979 Change Log
Louie
Post by Louie » Wed Jul 09, 2003 7:07 am
Build Number: 979
Development Status: EOL
Final Code ETA: September 17, 2003
1.0.978.4
  • Fixed an issue when setting the "Statistics" Line Speed to 0 would crash SmartFTP.
  • Fixed a spacing issue with "Host" addresses via the favorites dialog.
  • Fixed buffer overflows with "Global Queue" operations.
  • Fixed a bug with "Speed Limits" not saving the settings correctly. via the favorites.
1.0.978.6
  • Fixed default favorite setting for "Protocol Family Preference" .
  • Fixed missing "host" names for "Total Commander" imports.
1.0.978.7
  • Fixed an issue with the "Set Password" function via the "Favorites".
  • Fixed menu icon issues, for the "Log Control" context menu.
  • Fixed an issue with the "Edit Favorites" column.
1.0.978.8
  • Fixed a problem where the dialup setting was not correctly saved.
1.0.978.9
  • Fixed the "Double Click Action -> "Queue - Global Source".
  • Fixed the "Select Folder" option, via the "Destination", in the the Global Queue "Properties.
1.0.978.10
  • Added "UPNP (Universal Plug and Play) GetExternalIPAddress" support.
    |- Dynamic port forwarding for "PORT" mode, used for non-default FTP port (21) connections.
  • Fixed an issue where a z/OS system was detected as a a "UNIX" system.
1.0.978.11
  • Added ICS (Internet Connection Sharing) / ICF (Internet Connection Firewall) support.
1.0.978.12
  • When connecting over a favorite item, the windows position and the column header settings are now saved and restored the next time.
  • UPNP / ICS / ICF dynamic port support disabled for private ip's.
1.0.978.13
  • Fixed a small problem with the "Download Hidden File" custom command.
  • FXP IPv4 <-> IPv6 is now fully functional.
1.0.978.14
  • Support for "PRET" command. See DrFTPD for complete details.
1.0.979.0
  • UPNP enabled by default.
  • Fixed the IP Repeater, which was broken from an earlier build.
  • "Statistic" format for the favorites "Create Time" and "Last Connected", has been changed from long to short format.
