SmartFTP 1.0.978 Change Log
Louie
Post by Louie » Tue May 06, 2003 8:08 am
Build Number: 978
Development Status: EOL
Final Code ETA: July 9, 2003
1.0.976.2
  • Fixed a font save problem in logview.
  • Better initial positions of "Favorites" and "Stats" windows.
1.0.976.3
  • Fixed a bug where "Quick Folders" weren't being saved.
1.0.976.4
  • Fixed some color issues with the "Statistics Popup" window feature.
1.0.976.5
  • Fixed the "138 days in use" bug.
    -| You need to reinstall SmartFTP and all .dat files must be deleted as well.
1.0.976.6
  • Fixed SOCKS5 bug when the hostname could not be resolved on the client machine.
  • Fixed possible dead lock in the "Queue->Show Log".
  • Workaround for "Show Raw Listing" crash caused by unicows.
  • Fixed dialog font problems under Win9x.
1.0.976.7
  • "Queue Log Manager" partly rewritten to avoid dead locks.
1.0.976.8
  • Fixed a problem in the "Global Queue" for items using favorite settings and a proxy.
1.0.976.9
  • Fixed the "Custom Command" hotkey bug.
  • Made some clipboard work arounds.
1.0.976.10
  • Optimized drag over (MDI bar, Queue Tabs, Window Title) timers.
  • Added support for "PSOSYSTEM" voicemail server.
1.0.976.11
  • Added new VMS date format.
1.0.976.12
  • Statusbar uses global settings for size display format.
  • Queue: Fixed crash in "Queue Log Manager" when many items(s) were processed.
  • Queue: Local folder will now be created if it doesnt exist for file item downloads.
1.0.976.13
  • Added "Disconnect" and "File Exists" sound events.
  • Fixed bug with Favorites: Tranfser->Files->On File Exist : Download setting.
1.0.977.0
  • Added "Protocol Family Preference" (IPv6) support.
1.0.977.1
  • Rewrote SOCKS4, SOCKS4A, SOCKS5 proxy support.
1.0.977.2
  • Added "IO Buffer Size" setting to "Favorite Item".
1.0.977.3
  • Restored the resolving of hexadecimal IP's.
1.0.977.4
  • Fixed a nasty drag & drop bug (GPF).
  • Manual IP / address for PORT is now resolved.
1.0.977.5
  • New "Connecting ... " and "Connected .." notify messages.
  • Added "Protocol Family Preference" settings (global and favorite).
1.0.977.6
  • Win9x: Fixed memleak in Speed control caused by TransparentBlt.
1.0.977.7
  • Fixed SOCKS4, SOCKS5 upload bug.
1.0.977.8
  • Fixed "Favorite Setting" but with queue items.
  • Upload / Download "Transfer Buffer Sizes" now hard coded.
  • IPv6 support (for IPv6 ips use [IP]).
