Any way to see Passwords?
paco
Post by paco » Sun Mar 16, 2003 1:04 pm
Is there a way to see the password to a server on the login bar? (instead of the asterisks) thanks
fnheiden
Re: Any way to see Passwords?
Post by fnheiden » Sun Mar 16, 2003 1:49 pm
Simply disable the option 'Hide Passwords' at 'Tools, Settings, Display'.
But I don't recommend this setting because every other user on your computer can spy on your passwords much easier this way.
~ Florian
paco
Post by paco » Sun Mar 16, 2003 3:36 pm
thanks. i can't believe i didn't notice that.
i will 'rehide' the pw after i remind myself of it. i want to connect to a server from a different machine and i can't remember, nor find a record, of the pw.
