Exception
samuelnaierman
Exception
Post by samuelnaierman » Fri Mar 07, 2003 5:14 pm
I get an error every time I try to open a folder. It says Access Denied. The problem is that his happens with only one of the servers I access and it started to happen recently. The way the error appears is with an Exception Handler.
How can I fix this
Louie
Re: Exception
Post by Louie » Sat Mar 08, 2003 7:27 pm
Please upgrade to to the latest build of SmartFTP:
And for the "access denied" error, this might be of help to you:
https://www.smartftp.com/support/kb/inde ... view&id=86
