SmartFTP and MS Outlook problem
jazzzman
Post by jazzzman » Wed Feb 12, 2003 4:51 pm
Hi all,
my problem is when i open MS Outlook not Express and SmartFTP is running in the background........
then SmartFTP pops up and tryin to connect to the FTP address i have in the clipboard......... it connects to that FTP address a dozen times at once................even if i have prompt enabled on URL catch.
and it seems like it connects for each contact i have in MS Outlook
its quite annoying.......but my only workaround is to copy somin else into the clipboard then an address...............but i tend to forget it most of the time.......
maybe someone knows anything about this.
I am using build 971 ...... i din't upgrade so far coz its the stablest version i have................ never crashed not in 98SE and not in XP...
i had a lot of problems with prior versions....so i will stretch the update till its not avoidable......but i dont think that the new build will fill it....
thx in advance
cheers
Re: SmartFTP and MS Outlook problem
Post by mb » Wed Feb 12, 2003 5:21 pm
The problem is with MS Outlook + co.
