Start Up folder
Jason.K
Start Up folder
Post by Jason.K » Sat Feb 01, 2003 8:58 am
I have used WS_FTp an dnow starting to use Smart FTP but can't work out how to set the startup folder. In WS_FTP you just clicked on the startup tab and type in the address in the local folder text box. How to I set the start up folder as thats the only way I can access my sites files.
Re: Start Up folder
Post by mb » Tue Feb 04, 2003 9:35 pm
Specify the "Local Path" in the settings of your favorite. As soon as you're connected press Ctrl+G or Menu: Commands->Open Local Directory.
