Global queue error?
zofm
Global queue error?
Post by zofm » Tue Nov 26, 2002 1:45 pm
I often use the global queue, but recently the files was downloaded with wrong size (for example, on the server a file is 15MB large.. after download on my computer the file is 14,7MB large).
For SmartFTP the download was successfully and the file was deleted from queue...
In a list of files, any file was downloaded incorrect with different size (14,8MB ... 14,9MB ... 14,7MB).
Thanks for any suggestions
PS. I've SmartFTP licensed (V.1.0 Build 971)
Re: Global queue error?
Post by mb » Tue Nov 26, 2002 2:32 pm
Do you have the latest developer build installed?
BTW: 14.7MB is somthing like 15'000'000 bytes.
Thanks for buying a license!
zofm
Post by zofm » Tue Nov 26, 2002 3:20 pm
Hi Mat,
thanks for your reply
Well.. 14,7MB is something like 15,000,000 bytes but, for example, when I download a list of .RAR files (15,000,000 bytes each), SmartFTP save any file with a different size. So, when I've downloaded that files, winRAR cannot uncompress the list of files because are of wrong or different size (I've tried many times).
Now, I test all with the developer build...
Byez
Post by mb » Tue Nov 26, 2002 5:31 pm
What if you download the files with "Download->Direct"?
I could also be a server issue. What FTP server is on the remote site?
zofm
Post by zofm » Tue Nov 26, 2002 5:53 pm
Sorry Mat, but i think the problem is the transfer type. At the moment I force the transfer type to Binary... I notify you when download finished
Thanks again!
Bye
Post by mb » Tue Nov 26, 2002 9:57 pm
Yeah might be ..
Check your Settings->Transfer "ASCII File" extensions.
You can also right click on the item in the global queue and select "Show Log" to see what transfer type is being used.
