more userfriendly keepass integration
d-p
Post by d-p » Wed May 13, 2015 11:20 am
Hello,
I would really appreciate if you could change the way smartftp reacts, when the keepass database closes, but smartftp has still an active connection using a password. Currently you get an "Unknown Error" alert window, that cannot be closed (it reopens again immediately after it was closed). With that you can only kill smartftp or unlock the password database again, to do something other in smartftp.
Well, if you could change it at least to a confirm window with an 'ok' and 'cancel' button and if you choose cancel, it closes the opened remote browsers.
Best regards,
Daniel
PS: if you need to know. I am using SmartFTP Ultimate 6.0.2136.0 with windows 8.1
d-p
Re: more userfriendly keepass integration
Post by d-p » Mon Nov 07, 2016 2:25 pm
it is still the same problem.
In addition if you have open two or more password database opened in keepass but you only want to have smartftp connected with one, smartftp keeps requesting for read access for the (active) database. Even when you say "no" the request popup comes again immediately, making it impossible to work with keepass without granting access or force kill smartftp with taskmanager!
Post by mb » Mon Nov 07, 2016 4:42 pm
Please contact support: menu: File - Help - Request Support
