Ability to create right-click server commands items to send to server.
J. Scott Elblein
Post by J. Scott Elblein » Wed Jun 25, 2014 12:51 pm
Would be nice if we could send raw server commands to the server by creating our own otems in the right-click context menu.
i.e. I highlight a file.zip, right-click and select "Raw Commands", it pops out any custom subitems I've created, in this case I'd have an "Unzip" item. When I click that sends the command "unzip file.zip" (the file.zip would probably need to be a variable such as %1).
The raw commands could be any command a linux server takes, including any params. I tried doing "unzip file.zip" in the same folder as a file.zip using the current "Command Line" that's in SFTP and nothing at all happened. Plus, I would have to manually type any raw commands each time, if it did already work, instead of some nice, clickable, custom commands.
Re: Ability to create right-click server commands items to send to server.
Post by mb » Wed Jun 25, 2014 1:37 pm
Once you are connected to an FTP server you can find the custom commands menu in the main menu:
File - Custom Commands
A dedicated menu item in the item context menu is not planned as the custom commands are only used by a few users.
