0x80072EE2
avliet
0x80072EE2
Post by avliet » Tue Feb 04, 2014 10:11 am
When using SmartFTP Lib on a Windows 2008 computer I get the following error in vb.net:
Exception from HRESULT : 0x80072EE2
I get doing the first step within the sorfware: check the license.
Reg,
Arjan
Re: 0x80072EE2
Post by mb » Tue Feb 04, 2014 6:01 pm
It means unable to connect to the license server. Probably a firewall/AV issue.
avliet
Re: 0x80072EE2
Post by avliet » Wed Feb 05, 2014 8:01 pm
Thanks! This server is not on the internet. We will connect it and try again.
Re: 0x80072EE2
Post by mb » Wed Feb 05, 2014 9:04 pm
Alternatively you can also use the Offline Activator:
https://www.smartftp.com/Products/Smart ... vation.zip
avliet
Re: 0x80072EE2
Post by avliet » Wed Dec 10, 2014 4:01 pm
Is there also a 32 bits version of the offlineActivation.exe?
Re: 0x80072EE2
Post by mb » Wed Dec 10, 2014 4:49 pm
The offline activator is only available as a 32-bit version. There is no need for a 64-bit version.
