Setup
mlafrance
Setup
Post by mlafrance » Fri Oct 25, 2013 8:18 pm
Hi!
Until Windows 8.1, I had no problem using it. After the update, I wasn't able to connect anywhere. So I tried to desinstall and reinstall the software and now, I get the "The Smart FTP Client 64-bit setup does not work on your computer. Please download and run the 32-bit setup."
I have a 64 bits OS.
No problem, I'll try the 32 bits setup.
Now, i ger the "Use dedicated 64-bit setup on Windows 64-bit Editions".
Can you help me with this case?
Thank you!
Re: Setup
Post by mb » Fri Oct 25, 2013 8:54 pm
It's a bug in Windows 8.1 that causes this problem. Right-click on the .exe, run as Administrator.
mlafrance
Re: Setup
Post by mlafrance » Mon Oct 28, 2013 11:48 am
As simple as that! It's working perfectly again! Thank you for your support and quick answer!
