Sftp connection
Gior
Sftp connection
Post by Gior » Wed Sep 18, 2013 1:04 pm
Hi guys,
we are testing SmartFtpClient and SmartFtpLibrary (trial license) in order to check if it is ok for our job.
Trying a SFTP connection what we obtain is this:
<blockquote class="ipsBlockquote">
[14:47:50] SmartFTP v5.0.1339.0
[14:47:50] Resolving host name "xxxx.xxx.xxx"
[14:47:50] Connecting to 111.111.111.111 Port: 22
[14:47:50] Connected to xxxx.xxx.xxx.
[14:47:50] SSH protocol version reply. Client Id: SSH-2.0-SmartFTP
[14:47:50] SSH-2.0-Maverick_SSHD
[14:47:50] Starting SSH session. Remote Id: "SSH-2.0-Maverick_SSHD"
[14:47:50] Key Exchange Algorithm: diffie-hellman-group-exchange-sha1
[14:47:52] Server "ssh-dss" host key fingerprint: 53:BC:12:63:8B:C5:DC:6A:F5:75:17:44:E2:91:1A:5B
[14:47:52] Key exchange completed.
[14:47:52] Host Key Algorithm: ssh-dss
[14:47:52] Client to Server Encryption: aes192-cbc
[14:47:52] Server to Client Encryption: aes192-cbc
[14:47:52] Session HMAC: hmac-sha1
[14:47:52] Client to Server Compression: none
[14:47:52] Server to Client Compression: none
[14:47:52] Requesting service "ssh-userauth".
[14:47:52] RTT: 289.046 ms
[14:47:52] Authentication request. Method: none
[14:47:52] Received authentication banner message.
[14:47:52] Server supported authentications: password,publickey
[14:47:52] Authentication request. Method: password
[14:47:52] User authentication successful.
[14:47:52] SSH session established.
[14:47:52] Detected Server Software: Maverick SSHD
[14:47:52] Opening channel 0.
[14:47:53] Channel successfully opened (Local=0, Remote=0).
[14:47:53] Requesting subystem "sftp" (Local=0, Remote=0).
[14:47:53] Sending FXP initialization. Protocol version=6.
[14:47:53] SFTP packet with unexpected request id 0 received.
[14:47:53] SSH channel closed by client.
[14:47:53] Connect failed. Error=0x80004005
[14:47:53] Disconnecting.
[14:47:53] Þ6#[~OÑe{Ë
[14:47:53] È¡E ±SíeáDS§ˆÌOvÌqB+ÍiÉ7÷Úub“Gà×Ξ¹bcò=ÔÉX’¶_¡ku
[14:47:53] Client closed the connection.
</blockquote>
Does anybody know the reason and a way to solve it?
Thank you,
Giorgio
Re: Sftp connection
Post by mb » Wed Sep 18, 2013 4:28 pm
Can you connect with SmartFTP client?
Gior
Re: Sftp connection
Post by Gior » Thu Sep 19, 2013 7:26 am
No, this log is generated by SnartFTP Client...
Re: Sftp connection
Post by mb » Thu Sep 19, 2013 10:25 am
Can you send the IP address of the server to support at smartftp.com?
Gior
Re: Sftp connection
Post by Gior » Thu Sep 19, 2013 11:27 am
Yes but I suppose you would need user and password too... Isn't it?
In such a case may I send it to you in a private message?
Giorgio
Re: Sftp connection
Post by mb » Thu Sep 19, 2013 11:53 am
Correct. I have contacted you by email.
