Transfer Queue frozen
Alart
Post by Alart » Tue Aug 13, 2013 9:17 pm
Hi There,
The transfer queue has frozen I am unable to remove or start it is justing hanging there.
I have upgraded sftp and restarted my computer but the queue is stil there.
How can I delete them all to get on with the process I have been at this for two hours.
Can you please help.
Regards
Alan
Re: Transfer Queue frozen
Post by mb » Tue Aug 13, 2013 11:12 pm
Select All (Ctrl+A), right click on the selection, and select Remove from the context menu. Or manually delete the %appdata%\SmartFTP\Client 2.0\Transfer Queue.xml file when SmartFTP is closed.
