SmartFTP Client 6.0 Change Log
Post by mb » Fri Oct 28, 2011 6:45 pm
Product lifecycle: EOL (End-of-life)
All future entries will be published as new posts. Scroll down to see the newest entry.
6.0 Build 2001 21. April 2014
  • User Interface
    • New ribbon interface
    • Office 2013 theme
    • High dpi support for 125% - 250% dpi
    • Replaced all toolbar bitmaps with multi-resolution icons
    • Added support for mouse over scrolling
  • Remote Browser
    • Connection sharing between Remote Browser and Transfer Queue
    • Removed connect/reconnect/disconnect buttons and functionality
    • The root folder / is now handled like any other file folder
    • Unified search implementation/interface
  • Text Editor
    • Added clipboard ring
    • Dynamic styling is now done when the main thread is idle
    • New quick find & replace
    • New indicator bar which shows annotations, search highlights and spelling errors on the right side of the scrollbar
    • A progress indicator is shown during lexing/highlighting
    • The number of selected characters and lines is now displayed in the statusbar
    • Support for Microsoft spellchecker with auto correction
    • Added support for code preview. Enable it in the settings.
    • Added Visual Compare of 2 documents
    • Added the ability to add column markers to the ruler bar
  • Modernization
    • Unified search implementation (Removed legacy search implementation)
    • Replaced CryptoAPI with CNG
    • Replaced custom task dialog implementation with native implementation
    • Transfer filters use Canonical Advanced Query Syntax (AQS)
  • Cleanup
    • Removed all Windows XP specific code and workarounds
    • Removed Rapidshare
  • System Requirement: Windows 7 SP1, Windows 2008 R2 SP1, Windows 8, Windows 2012 (R2), Windows 8.1
Re: SmartFTP Client 6.0 Change Log
Post by mb » Tue Apr 22, 2014 12:54 pm
6.0 Build 2002 23. April 2014
  • Fix: Remote Browser: Bookmarks
  • Fix: Windows 8.1: Preview pane
  • Fix: Preview pane state was not restored
  • Fix: Remote Browser: Double click was broken when the "[x] Use check boxes to select items" option was enabled.
Post by mb » Wed Apr 23, 2014 4:05 am
6.0 Build 2003 23. April 2014
  • Fix: Remote Browser: Unix group, owner
  • Fix: Remote Browser: Edit
  • Fix: Multi-part downloads
Post by mb » Wed Apr 23, 2014 7:38 pm
6.0 Build 2006 28. April 2014
  • Fix: WebDAV
  • Fix: Favorites Browser: Favorite name change was not always reflected in the view
  • Remote Browser: Added Open With... context menu if there are no file associations
Post by mb » Mon Apr 28, 2014 9:10 pm
6.0 Build 2007 30. April 2014
  • Fix: Quick Search
  • Fix: Favorite Browser: New favorite
  • Fix: Remote Browser: Item check boxes
  • Fix: Remote Browser: Edit (once again)
Post by mb » Wed Apr 30, 2014 12:40 pm
6.0 Build 2008 1. May 2014
  • Fix: Crash when creating a new connection through the login bar
  • Better fail-over mechanism for invalid initial paths. Initial paths have to be absolute (starting with a /)
Post by mb » Thu May 01, 2014 8:57 pm
6.0 Build 2009 2. May 2014
  • Fix: Windows 8: Remote Browser: Open with... and "make default association"
  • Settings: Single instance is now enabled by default
  • Fix: Remote Browser: Upload failed to queue the items under some circumstances
Post by mb » Fri May 02, 2014 9:21 pm
6.0 Build 2012 6. May 2014
  • Fix: Remote Browser: Various issues with folder redirection and navigation pane
  • Fix: Transfer Queue: Multi part transfers using the FTP protocol
  • Fix: Transfer Queue: Removed unnecessary parent folder resolution during upload
  • Fix: Password Recovery Tool: Failed to run on 32-bit platform
  • Fix: Log Control: Set font
  • Remote Browser: New Copy Url function in ribbon
  • Updated Italian localization
Post by mb » Mon May 05, 2014 8:01 pm
6.0 Build 2015 7. May 2014
  • Fix: Draw issues if the taskbar is attached to the left side of the screen
  • Fix: Uninitialized variable caused various issues
  • Fix: Freeze when Sync navigation and Link browser was enabled
  • Fix: Remote Browser: View
Post by mb » Wed May 07, 2014 12:59 am
6.0 Build 2017 13. May 2014
  • Updated Office 2013 theme
  • Fix: Serv-U returns incorrect value in Win32.ea property
  • Fix: Incorrect behavior when entering a path to a file into the address input box
  • Fix: Telnet
  • Windows 7: Workaround for systems where KB2533623 has not been installed
  • Fix: Backspace in shell view
