Error=0x80004005
toadstoy2
Error=0x80004005
Post by toadstoy2 » Fri Oct 21, 2011 3:15 am
Connection attempt 2...
[22:56:32] Resolving host name "ftp.dummycorp.net"
[22:56:32] Connecting to 12.345.67.890 Port: 101
[22:56:32] Connected to ftp.dummycorp.net.
[22:56:33] Server closed connection
[22:56:33] An established connection was aborted by the software in your host machine.
[22:56:33] Connect failed. Error=0x80004005
[22:56:33] Waiting to retry (30s)...
host name and connecting to IP inserted
everything is up-to-date .. everything is correct on the other end .. (verified after seeing this as a response to the same problem:
Posted 23 July 2011 - 02:22 PM
Wrong host name or no FTP server is running on this IP.)
the host name & IP & port are all correct
seems the problem is on this end
fresh install on a different computer got the same results..
turned off firewall completely .. nothing changed
so .. any ideas ?
Re: Error=0x80004005
Post by mb » Fri Oct 21, 2011 4:10 am
Wrong hostname/ip/port
toadstoy2
Post by toadstoy2 » Sat Oct 22, 2011 4:49 am
I had spoken with tech support at our webhost after I had done some searching for solutions to the "Error=0x80004005" (one of which was your "Wrong hostname/ip/port" response to someone else.. which was why I went to our webhost first)
and they stated hostname/ip/port were correct..their suggestion was for us to use a different client .. simple enough for them to suggest since it's not money they'd spent
so .. anything else for us to try ?
toadstoy2
Post by toadstoy2 » Sat Oct 22, 2011 6:24 am
Connection attempt 3...
[02:12:09] Resolving host name "ftp.dadawghouse.net"
[02:12:09] Connecting to 66.235.218.166 Port: 21
[02:12:09] Connected to ftp.dadawghouse.net.
[02:12:10] Server closed connection
[02:12:10] An established connection was aborted by the software in your host machine.
[02:12:10] Connect failed. Error=0x80004005
[02:12:10] Waiting to retry (30s).
this was the result from trying with no firewalls up tonight(this morning)
we have some updating to do and can't without getting this issue resolved
Post by mb » Sat Oct 22, 2011 10:01 am
Please contact technical support as following:
https://www.smartftp.com/support/kb/how- ... f2653.html
