Upload doesn't work properly
youthengirls
Post by youthengirls » Thu Oct 13, 2011 9:35 pm
My uploads keep timing out with the new version of SmartFTP. The old version works fine, but I can't even find it anymore. The files 'retry' for 1-5 times until it finally works. I tried changing PASSV/ACTIVE modes and disabling cache. Does not work.
[14:18:24] STOR all.php
[14:18:39] 150 Ok to send data.
[14:18:39] 5358 bytes transferred. (354 bytes/s) (00:00:15)
[14:19:39] Timeout (60s).
[14:19:39] Active Help: https://www.smartftp.com/support/kb/74
[14:19:40] Client closed the connection.
[14:19:40] Setting properties (Date modified) of "/home/domains/mydomain/admin/all.php"
[14:19:40] Transfer failed.
[14:19:40] Operation End
Re: Upload doesn't work properly
Post by mb » Fri Oct 14, 2011 1:42 am
We have sent you the answer per email.
