Schedule transfer
anthonyleung
Schedule transfer
Post by anthonyleung » Fri Sep 23, 2011 5:48 am
Hi Support,
I want to setup a schedule task for daily upload data to remote server. The SmartFTP client installed on Windows 2003 server and using trial version 4.0. When SmartFTP client closed and account logoff from Windows, the scheduler didn't work at all. Is it limitation for trial version? Any possible solution? Thank you.
Anthony Leung
Re: Schedule transfer
Post by mb » Fri Sep 23, 2011 11:00 am
Did you setup SmartFTP to run as a service?
https://www.smartftp.com/support/kb/how- ... f2624.html
During the trial a dialog is shown at start which waits for user input. Since SmartFTP runs on a different screen, it will be stuck there. Once you have activated it with a license (Professional Edition or higher) it will no longer show the trial dialog and the execution will continue.
