Ordner werden nicht aufgelistet
rs5
Post by rs5 » Wed Aug 24, 2011 12:05 pm
Hallo,
ich verwende Serv-U als FTP-Server.
Beim Login mit smartftp werden Ordner/Links nicht aufgelistet. Beim Test (für eine Kaufentscheidung) mit anderen Clients, Total Commander, FTP Voyager, Flashfxp, Filezilla und ws ftp funktioniert es einwandfrei.
Aktive FTP habe ich über die Firewall (ISA-Server) gesperrt.
Welchen Fehler habe ich übersehen?
Hier die Log:
[14:01:48] SmartFTP v4.0.1209.0
[14:01:48] Resolving host name "kibo2.***.de"
[14:01:48] Connecting to xxx.xxx.192.48 Port: 21
[14:01:48] Connected to kibo2.xxx.de.
[14:01:48] 220 Serv-U FTP Server v10.2 ready...
[14:01:48] USER root
[14:01:48] 331 User name okay, need password.
[14:01:48] PASS (hidden)
[14:01:48] 230 User logged in, proceed.
[14:01:48] SYST
[14:01:48] 215 UNIX Type: L8
[14:01:48] Detected Server Type: UNIX
[14:01:48] RTT: 42.504 ms
[14:01:48] FEAT
[14:01:48] 211-Extensions supported
[14:01:48] UTF8
[14:01:48] OPTS MODE;MLST;UTF8
[14:01:48] CLNT
[14:01:48] CSID Name; Version;
[14:01:48] HOST domain
[14:01:48] SITE PSWD;SET;ZONE;CHMOD;MSG;EXEC;HELP
[14:01:48] AUTH TLS;SSL;TLS-C;TLS-P;
[14:01:48] PBSZ
[14:01:48] PROT
[14:01:48] CCC
[14:01:48] SSCN
[14:01:48] RMDA directoryname
[14:01:48] DSIZ
[14:01:48] AVBL
[14:01:48] EPRT
[14:01:48] EPSV
[14:01:48] MODE Z
[14:01:48] THMB BMP|JPEG|GIF|TIFF|PNG max_width max_height pathname
[14:01:48] REST STREAM
[14:01:48] SIZE
[14:01:48] MDTM
[14:01:48] MDTM YYYYMMDDHHMMSS[+-TZ];filename
[14:01:48] MFMT
[14:01:48] MFCT
[14:01:48] MFF Create;Modify;
[14:01:48] XCRC filename;start;end
[14:01:48] MLST Type*;Size*;Create;Modify*;Perm;Win32.ea;Win32.dt;Win32.dl
[14:01:48] 211 End (for details use "HELP commmand" where command is the command of interest)
[14:01:48] CSID Name=SmartFTP;Version=4.0.1209.0;
[14:01:48] 200 Name=Serv-U; Version=10.2.0.2; OS=Windows Server 2003; OSVer=5.2.3790; CaseSensitive=0;
[14:01:48] OPTS UTF8 ON
[14:01:48] 200 OPTS UTF8 is set to ON.
[14:01:48] OPTS MLST Type;Size;Create;Modify;Perm;Win32.ea;Win32.dt;Win32.dl;
[14:01:48] 200 MLST OPTS Type;Size;Create;Modify;Perm;Win32.ea;Win32.dt;Win32.dl;
[14:01:48] Detected Server Software: Serv-U
[14:01:48] PWD
[14:01:48] 257 "/" is current directory.
[14:01:49] TYPE A
[14:01:49] 200 Type set to A.
[14:01:49] MODE Z
[14:01:49] 200 MODE Z ok.
[14:01:49] PASV
[14:01:49] 227 Entering Passive Mode (xxx,xxx,192,48,106,43)
[14:01:49] Opening data connection to xxx.xxx.192.48 Port: 27179
[14:01:49] MLSD
[14:01:49] 150 Opening BINARY mode data connection for MLSD.
[14:01:49] 143 bytes transferred. (2,84 KB/s) (49 ms)
[14:01:49] 226 Transfer complete. 427 bytes (143 compressed to 33,49%) transferred. 0,14 actual KB/sec, 0,42 effective KB/sec.
Grüße
PS. die Log von Flashfxp mit Auflistung der Ordner
WinSock 2.0 -- OpenSSL 1.0.0d 8 Feb 2011
[R] Verbindung herstellen zu kibo2.xxx.de <Woogmorgen> -> DNS=kibo2.xxx.de IP=xxx.xxx.192.48 PORT=21
[R] Verbunden mit kibo2.xxx.de <Woogmorgen>
[R] 220 Serv-U FTP Server v10.2 ready...
[R] USER root
[R] 331 User name okay, need password.
[R] PASS (hidden)
[R] 230 User logged in, proceed.
[R] SYST
[R] 215 UNIX Type: L8
[R] FEAT
[R] 211-Extensions supported
[R] UTF8
[R] OPTS MODE;MLST;UTF8
[R] CLNT
[R] CSID Name; Version;
[R] HOST domain
[R] SITE PSWD;SET;ZONE;CHMOD;MSG;EXEC;HELP
[R] AUTH TLS;SSL;TLS-C;TLS-P;
[R] PBSZ
[R] PROT
[R] CCC
[R] SSCN
[R] RMDA directoryname
[R] DSIZ
[R] AVBL
[R] EPRT
[R] EPSV
[R] MODE Z
[R] THMB BMP|JPEG|GIF|TIFF|PNG max_width max_height pathname
[R] REST STREAM
[R] SIZE
[R] MDTM
[R] MDTM YYYYMMDDHHMMSS[+-TZ];filename
[R] MFMT
[R] MFCT
[R] MFF Create;Modify;
[R] XCRC filename;start;end
[R] MLST Type*;Size*;Create;Modify*;Perm;Win32.ea;Win32.dt;Win32.dl
[R] 211 End (for details use "HELP commmand" where command is the command of interest)
[R] CLNT FlashFXP 4.0.0.1548
[R] 200 Noted.
[R] OPTS UTF8 ON
[R] 200 OPTS UTF8 is set to ON.
[R] PWD
[R] 257 "/" is current directory.
[R] MODE Z
[R] 200 MODE Z ok.
[R] PASV
[R] 227 Entering Passive Mode (xxx,xxx,192,48,107,81)
[R] Datenkanal-IP öffnen: xxx.xxx.192.48 PORT: 27473
[R] MLSD
[R] 150 Opening BINARY mode data connection for MLSD.
[R] 226 Transfer complete. 84 bytes (39 compressed to 46,43%) transferred. 0,04 actual KB/sec, 0,08 effective KB/sec.
[R] Verzeichnis geladen: 72 bytes in 0,49 Sekunden (0,1 KB/s)
Re: Ordner werden nicht aufgelistet
Post by mb » Wed Aug 24, 2011 12:45 pm
Versuch mal compression in SmartFTP zu disablen: Favorite Properties->FTP->Compression dann List.
Haettest du vielleicht ein test account auf dem server damit wir das hier versuchen koennen zu reproduzieren? Weil Serv-U hat schon mehrfach probleme (mit allen FTP clients und nicht nur mit SmartFTP) mit compression (MODE Z) gemacht aber dann meistens die alten Versionen. Serv-U 10.5 funktioniert hiert ohne Probleme zum Beispiel.
rs5
Post by rs5 » Wed Aug 24, 2011 1:34 pm
Hallo,
"Versuch mal compression in SmartFTP zu disablen: Favorite Properties->FTP->Compression dann List."
auf none gesetzt hat das Problem gelöst. Herzlichen Dank für die schnelle Antwort und Hilfe.
Jetzt steht dem Kauf von smartftp nichts mehr im Weg.
Viele Grüße
Post by mb » Wed Aug 24, 2011 1:36 pm
Falls du moechtest dass wir das Problem naeher angucken, kannst du uns auch direkt per email (an support@) kontakieren.
