Renaming local files pressing F2 doesn't work anymore
Shabba
Post by Shabba » Mon Aug 08, 2011 10:33 am
I usually work very often with shortkeys. And so I use to press F2 to rename a file. With remote files this shortkey still works fine but with local files F2 doesn't have any effect. I know that this worked a view time ago. I already reinstalled SmartFTP completely without any effect. So what's the problem?
Is there any context to another phenomen? When I connect a server via a favourite and there is opened a local window, too, the focus is on Desktop folder an NOT on the folder stated in the favourite.
Re: Renaming local files pressing F2 doesn't work anymore
Post by mb » Mon Aug 08, 2011 10:36 am
Post the system information from the menu: help->About dialog
Shabba
Post by Shabba » Mon Aug 08, 2011 10:41 am
Post by mb » Mon Aug 08, 2011 10:53 am
Try to close the preview control.
Shabba
Post by Shabba » Mon Aug 08, 2011 10:55 am
That's it! I'm flabbergasted!!! :-o Now renaming files and folders with F2 works again!
Is this a bug?
Post by mb » Mon Aug 08, 2011 12:57 pm
Yes. The next build will come with a bug fix.
Shabba
Post by Shabba » Mon Aug 08, 2011 1:05 pm
Thank you very much for that great help !!!
Post by mb » Tue Aug 30, 2011 12:09 am
The new build is available now. Please give it a try: https://www.smartftp.com/download/
