replication bug?
rjb
replication bug?
Post by rjb » Wed Aug 03, 2011 4:43 pm
I would like to report the following behavior. I have scheduled task to copy a directory on a server (and all its contents including subfolders) to a local directory. There is a directory on the server named “07-20-11 Order”. SmartFTP first copied this directory to my local drive as “07-29-11 Order”. In subsequent runs of this task this directory and all of its contents is being copied as “7-29-11 Order”, without the preceeding zero. If I delete either the “07…” or “7…” directories from my local drive, when the task runs it recreates the one I deleted. This seems very strage and is resulting in a 2GB folder being duplicated on my local machine.
Re: replication bug?
Post by mb » Wed Aug 03, 2011 4:51 pm
It is hard to see why SmartFTP would randomly remove characters from file/folder name?
rjb
Post by rjb » Fri Aug 05, 2011 1:42 pm
I agree. It is hard to see why. But this is what is happening and why I posted to this forum. Do you have any ideas? Or is this the extent of support that is available on this product?
Post by mb » Fri Aug 05, 2011 3:34 pm
We are unable to reproduce the problem. Also as I said, I do not think the problem is caused by SmartFTP.
rjb
Post by rjb » Sat Aug 06, 2011 2:05 pm
Unfortunately, I think you are not correct about this. The only application involved is SmartFTP. There is a directory on the server, a directory on the client, and SFTP. SFTP is scheduled to start up through Windows scheduler and then runs a copy scheduled task on instantiation. I see no other software involved.
Post by mb » Sat Aug 06, 2011 4:40 pm
Please provide detailed instructions on how to reproduce the problem on a fresh installation of SmartFTP on a newly setup of Windows 7. It is important that you try to reproduce the problem with at least steps as possible (e.g. without the Windows task scheduler, etc).
rjb
Post by rjb » Mon Aug 08, 2011 2:54 pm
I'm sorry, but I am not going to reinstall Windows to debug this. Thank you anyway.
Post by mb » Mon Aug 08, 2011 2:56 pm
You can install it on a VM or install SmartFTP on different computer and try to reproduce the problem.
