Erratic browers in ver 4.0.1207
EdRobichaud
Post by EdRobichaud » Sun Jul 31, 2011 4:01 pm
Using Win XP Pro (sp3), after updating version to 1207, I experienced loss of keyboard navigation in both the remote and local brower windows. Neither the arrow keys nor Enter work. Tried repair and a clean re-install - no help. Finally restored ver 1189 and all works OK.
Re: Erratic browers in ver 4.0.1207
Post by mb » Sun Jul 31, 2011 4:03 pm
Do you know how to reproduce the problem in a reliable way?
EdRobichaud
Post by EdRobichaud » Sun Jul 31, 2011 6:39 pm
Meant to add that 1207 seems to work fine in a Win7 system. Didn't really mean "erratic", the cursor keys and <Enter> do not work in any remote or local brower on my XP system.
Post by mb » Sun Jul 31, 2011 8:17 pm
I'm unable to reproduce this on our test systems. Try this:
https://www.smartftp.com/support/kb/how- ... f2625.html
EdRobichaud
Post by EdRobichaud » Fri Aug 05, 2011 4:23 pm
I've tried the registry hack above and and also tried installing ver 1209 - same (lack of) cursor key behavior. Re-installed ver 1189 and all seems OK.
Post by mb » Fri Aug 05, 2011 9:31 pm
It seems the problem is caused by the Preview control. As a temporary workaround, close the Preview control. We are sorry for your inconvenience.
Post by mb » Tue Aug 30, 2011 12:10 am
The new build is available now. Please give it a try: https://www.smartftp.com/download/
