Growl for Windows Notifications
tehShane
Post by tehShane » Fri Jun 10, 2011 6:32 pm
I'd like to submit a suggestion to add Growl for Windows support to SmartFTP, to supplement/replace the built-in pop-ups for transfer/queue events.
With so many Windows apps spitting out their own notifications, it's nice to use a system that helps manage and customize them.
The libraries to Growl-enable an application are very small, as is the code needed to push the notifications out.
In most of my own apps, I've implemented it in under 20 lines.
More information on Growl for Windows is available at http://www.growlforwindows.com/gfw/developers.aspx
Thanks for a great product!
Shane
Re: Growl for Windows Notifications
Post by mb » Fri Jun 10, 2011 6:43 pm
Good idea. Thanks for sharing.
Post by mb » Fri May 30, 2014 11:56 pm
As Growl for Windows is no longer actively developed we have decided against implementing a plugin for it.
