Can SmartFTP be used to Store and Share Word Docs for Editing
gelsner99
Post by gelsner99 » Thu Jun 09, 2011 12:22 am
Can I use FTP Client (which, of course, I already own) to upload Word Documents and share them with my business partner for jointly editing?
I will appreciate your advice greatly.
/ Gary E.
Re: Can SmartFTP be used to Store and Share Word Docs for Editing
Post by mb » Thu Jun 09, 2011 12:24 am
Every person using SmartFTP requires a license. If your business partner uses SmartFTP, he needs a license for it.
moginheden
Post by moginheden » Wed Jun 29, 2011 11:45 pm
smartftp transfers files around. But you need an ftp server to store the file on. Simply installing it on both you and your partner's computer is not enough. You need a server to host the file.
Also as far as I can tell, SmartFTP does not come with any versioning checks so if you are both working on the document at the same time there is no way to merge the changes, or even tell that the other person has it open for editing.
I'm not aware of any ftp program that does this.
