SmartFTP won't load
stefke
SmartFTP won't load
Post by stefke » Mon May 23, 2011 2:04 pm
Hi all,
I searched the forum (and I googled the problem) before I ended up writing this post. This means I tried rebooting, reinstalling, cleaning the registry, deleting the SmartFTP key in the registry, ...
What's the problem I got? SmartFTP simply doesn't load anymore, no splash screen, no nothing. The problem occured after I tried to install the latest version and the program told me I had to update my maintenance. Funny thing is the website doesn't let me pay for it. After I select the 3 year option, fill out the form and click next I just get a blank screen. I tried it in 4 different browsers ... no cigar.
I thought the problem with the payment might be a server side problem and so I continued the installation. Result? No more SmartFTP... (Up till now I'm still not able to pay.)
So I have two questions for the SmartFTP team:
1. How can I pay with my Mastercad without getting the blank screen after I filled out the form?
2. How do I get my beloved SmartFTP up and running?
FYI. Win 7 - 64bit
Thank you for any suggestions.
stefke
Re: SmartFTP won't load
Post by stefke » Mon May 23, 2011 2:17 pm
I don't know why I didn't try this before, but I decided to RDP to my pc at home and give the payment another try. Guess what. It worked. Maybe my office ip was temporarily blocked, I don't know.
Well at least we got half the problem solved now. I'll keep you posted on question number two.
stefke
Post by stefke » Mon May 23, 2011 2:39 pm
I noticed the process is showing up in the process window of the taskmanager for a short while (~ 5 to 10 secs), just to disappear.
Post by mb » Mon May 23, 2011 2:47 pm
It usually means that the file is already on the server and therefore the transfer is skipped.
stefke
Post by stefke » Thu May 26, 2011 12:38 pm
Post by mb » Thu May 26, 2011 1:09 pm
stefke
Post by stefke » Sat May 28, 2011 7:56 am
Thanks for replying, but I tried that already as I explained in the original post.
Any other ideas?
Post by mb » Sat May 28, 2011 9:41 am
Try to run it on a different user account.
stefke
Post by stefke » Mon May 30, 2011 10:03 am
I tried running it under different user accounts but ... still no cigar.
Would the results of doing this bring us any closer to a solution?
Post by mb » Mon May 30, 2011 11:52 am
If SmartFTP crashes during startup, yes:
- Install the latest version of SmartFTP to ensure that you really have the latest version
- Then follow in the instructions in the article. Don't forget to enable this:
If SmartFTP crashes during startup. Download the ShowDebugMessage.zip archive and double click the ShowDebugMessage - Enable.reg.
What you can also try is to enable debug logging:
https://www.smartftp.com/support/kb/how- ... f2613.html
