Reset Default settings
Elaine
Post by Elaine » Sat Jul 17, 2010 10:15 pm
When i conect to the remote server the format that is surposed to come up is not coming up.
I've watched the connect tutorial when i follow it i do not get the exact same end result all i get are name, size, file, and date modified columes. All the other boxes and areas are missing which doesn't allow me to contine.
i think i need the settings in the program to be adjusted and re-set to defaults. i really could do with someone telling or showing me how to do this i've been struggling with it for about a week!
Re: Reset Default settings
Post by mb » Sat Jul 17, 2010 10:16 pm
Elaine
Post by Elaine » Mon Jul 19, 2010 7:25 pm
The Client 2.00 file was not listed on the left only the following was there.
(Default)
ApplicationName
ConHeadings
ConLinks
LocatorName
MetaDataFileName
PDFFileName
Post by mb » Mon Jul 19, 2010 7:40 pm
They key is:
HKEY_CURRENT_USER\Software\SmartFTP\Client 2.0
Elaine
Post by Elaine » Mon Jul 19, 2010 8:02 pm
That seems to have worked. Thanks a million!!! If i have any more problems i'll get back to you. Hopefully now i'll be able to upload my site.
