Transfer Queue freezes SmartFTP interface
cferd
Post by cferd » Sun Oct 11, 2009 8:22 am
When transfering files, if the "Transfer Queue" pane is open, SmartFTP will always stop responding. The window will show (not responding) on top, the interface freezes and the only thing I can do is close the program. If left alone, the transfer will continue, but there's no way to know when it's done. With the "Transfer Queue" pane closed, everything works fine as far as I can tell.
Here's the system info:
Microsoft Windows Vista Home Premium Edition
Service Pack 2 (Build 6002)
CPU Speed           : 2605 MHz
Total Memory        : 1981 MB
Free Memory         :  884 MB
Version             : 4.0.1054.0
Time Stamp          : 2009-10-06 19:54:07
Platform            : x86
Maintenance         : 2010-02-24
Days in use         : 518
en-US
Version             : 8.0.6001.18813
Winsock             : 2.2
This has been going on now for a few updates, so if there's a way to go back to a 2.x version with my current license, please let me know.
Ferd
Re: Transfer Queue freezes SmartFTP interface
Post by mb » Sun Oct 11, 2009 4:09 pm
Please provide a crash/hang dump:
https://www.smartftp.com/support/kb/how- ... f2594.html
cferd
Post by cferd » Sun Oct 11, 2009 4:29 pm
The dump file is 130MB in size
Post by mb » Sun Oct 11, 2009 4:41 pm
Please upload it to www.rapidshare.com or to your server of choice.
cferd
Post by cferd » Sun Oct 11, 2009 6:15 pm
Post by mb » Sun Oct 11, 2009 7:17 pm
Thank you. Did you take the process dump before the application hung or afterwards?
cferd
Post by cferd » Sun Oct 11, 2009 8:15 pm
I'm not sure what you mean. I started SmartFTP, ran the command line provided and left the command window open, started a transfer with "Transfer Queue" open, the program hung, I closed the program and closed the command window in that order.
Post by mb » Sun Oct 11, 2009 8:22 pm
You should have run the command line after SmartFTP hang. Please try this:
1. Start SmartFTP
2. Start the Transfer Queue and make the application hang
3. Run the command line
cferd
Post by cferd » Sun Oct 11, 2009 8:42 pm
Post by mb » Sun Oct 11, 2009 10:46 pm
The problem is with psicon.dll. This file comes from Adobe and is used to display thumbnails/icons for .psd files.
To disable it:
1. regsvr32.exe /u C:\Program Files\Common Files\Adobe\Shell\psicon.dll
2. Or go to the registry and delete the following keys:
[HKEY_CLASSES_ROOT\CLSID\{0B6DC6EE-C4FD-11d1-819A-00C04FB69B4D}]
[HKEY_CLASSES_ROOT\.psd\ShellEx]
3. Or rename psicon.dll to psicon.disabled.dll
