Recursive Chmod
hardipe
Recursive Chmod
Post by hardipe » Wed Jul 01, 2009 7:12 am
Possible bug:
When you don't actually change an item's chmod, but only tick the "Apply to subfolders and -files too", it doesn't do so. If you change the chmod, it does so. So, in order to get it done recursively you have to change the chmod at least once. Usually twice, because you have to change the folder back to what it was before the recursion hack.
Request:
A separate recursive chmod for files and folders. Stripping the Read permission from Others is useful for folders, so the web users can't see the folder contents, but when it's applied to files as well then it's not always desirable.
Re: Recursive Chmod
Post by mb » Wed Jul 01, 2009 11:49 am
>Bug
Will be fixed asap.
>files/folder
We will implement this as well.
Re: Recursive Chmod
Post by mb » Fri Jul 17, 2009 11:54 am
Please check the latest version:
There is a new "Apply To..." button in the Properties dialog.
