Address/Login bar update
Obliterator
Post by Obliterator » Sat Jun 20, 2009 9:28 pm
Changing the login details in the address/login bar no longer works.
It informs you it has updated the address and prompts you to select an action.
There are no actions available other than cancel.
It then does not attempt to connect. Upon retrying the prompt is simply displayed again.
Re: Address/Login bar update
Post by mb » Sat Jun 20, 2009 9:58 pm
Can you post a screenshot?
Post by mb » Sat Jun 20, 2009 10:15 pm
Bug confirmed. Working on a fix.
Post by mb » Sun Jun 21, 2009 12:00 am
The bug has been corrected:
Thank you for reporting.
