I have a bug of deconnection on directory listing (Windows 7 RC French).
After a connection to a server, when I want list another directory, I have the message : Server closed connection.
In the log of my server (vsftpd), I don't have error.
If I try with Filezilla for example, I don't have problem.
Example :
First connection to the server :
[10:09:06] SmartFTP v3.0.1027.10
[10:09:07] Resolving host name "ftp.xxx.com"
[10:09:07] Connecting to [2001:x:x:x::x] Port: 21
[10:09:07] Connected to ftp.xxx.com.
[10:09:07] AUTH TLS
[10:09:08] 234 Proceed with negotiation.
[10:09:08] Connected. Exchanging encryption keys...
[10:09:08] Session Cipher: 168 bit 3DES
[10:09:08] TLS encrypted session established.
[10:09:08] Command channel protection set to Private.
[10:09:08] PBSZ 0
[10:09:08] 200 PBSZ set to 0.
[10:09:08] USER xxx
[10:09:08] 331 Please specify the password.
[10:09:08] PASS (hidden)
[10:09:08] 230 Login successful.
[10:09:08] SYST
[10:09:08] 215 UNIX Type: L8
[10:09:08] Detected Server Type: UNIX
[10:09:08] RTT: 67.380 ms
[10:09:08] FEAT
[10:09:08] 211-Features:
[10:09:08] AUTH SSL
[10:09:08] AUTH TLS
[10:09:08] EPRT
[10:09:09] EPSV
[10:09:09] MDTM
[10:09:09] PASV
[10:09:09] PBSZ
[10:09:09] PROT
[10:09:09] REST STREAM
[10:09:09] SIZE
[10:09:09] TVFS
[10:09:09] UTF8
[10:09:09] 211 End
[10:09:09] OPTS UTF8 ON
[10:09:09] 200 Always in UTF8 mode.
[10:09:09] PWD
[10:09:09] 257 "/"
[10:09:09] TYPE A
[10:09:09] 200 Switching to ASCII mode.
[10:09:09] PROT P
[10:09:09] 200 PROT now Private.
[10:09:09] EPSV
[10:09:09] 229 Entering Extended Passive Mode (|||64241|)
[10:09:09] Opening data connection to 2001:x:x:x::x Port: 64241
[10:09:09] LIST -aL
[10:09:10] Connected. Exchanging encryption keys...
[10:09:10] 150 Here comes the directory listing.
[10:09:10] Session Cipher: 168 bit 3DES
[10:09:10] TLS encrypted session established.
[10:09:10] 1459 bytes transferred. (4,01 Ko/s) (355 ms)
[10:09:10] 226 Directory send OK.
[10:09:14] CWD /A
[10:09:14] 250 Directory successfully changed.
[10:09:14] PWD
[10:09:15] 257 "/A"
[10:09:15] EPSV
[10:09:15] 229 Entering Extended Passive Mode (|||23157|)
[10:09:15] Opening data connection to 2001:x:x:x::x Port: 23157
[10:09:15] LIST -aL
[10:09:15] Connected. Exchanging encryption keys...
[10:09:15] 150 Here comes the directory listing.
[10:09:15] Server closed connection
[10:09:20] Resolving host name "ftp.xxx.com"
[10:09:20] Connecting to [2001:x:x:x::x] Port: 21
[10:09:21] Connected to ftp.xxx.com.
[10:09:21] AUTH TLS
[10:09:21] 234 Proceed with negotiation.
[10:09:21] Connected. Exchanging encryption keys...
[10:09:21] Session Cipher: 168 bit 3DES
[10:09:21] TLS encrypted session established.
[10:09:21] Command channel protection set to Private.
[10:09:21] PBSZ 0
[10:09:21] 200 PBSZ set to 0.
[10:09:21] USER releases
[10:09:21] 331 Please specify the password.
[10:09:21] PASS (hidden)
[10:09:21] 230 Login successful.
[10:09:21] SYST
[10:09:22] 215 UNIX Type: L8
[10:09:22] Detected Server Type: UNIX
[10:09:22] RTT: 66.864 ms
[10:09:22] FEAT
[10:09:22] 211-Features:
[10:09:22] AUTH SSL
[10:09:22] AUTH TLS
[10:09:22] EPRT
[10:09:22] EPSV
[10:09:22] MDTM
[10:09:22] PASV
[10:09:22] PBSZ
[10:09:22] PROT
[10:09:22] REST STREAM
[10:09:22] SIZE
[10:09:22] TVFS
[10:09:22] UTF8
[10:09:22] 211 End
[10:09:22] OPTS UTF8 ON
[10:09:22] 200 Always in UTF8 mode.
[10:09:22] PWD
[10:09:22] 257 "/"
[10:09:22] CWD /A
[10:09:22] 250 Directory successfully changed.
[10:09:22] PWD
[10:09:22] 257 "/A"
[10:09:22] CWD /B
[10:09:23] PWD
[10:09:23] 257 "/B"
[10:09:23] TYPE A
[10:09:23] 200 Switching to ASCII mode.
[10:09:23] PROT P
[10:09:23] 200 PROT now Private.
[10:09:23] EPSV
[10:09:23] 229 Entering Extended Passive Mode (|||55309|)
[10:09:23] Opening data connection to 2001:x:x:x::x Port: 55309
[10:09:23] LIST -aL
[10:09:23] Connected. Exchanging encryption keys...
[10:09:23] 150 Here comes the directory listing.
[10:09:23] Session Cipher: 168 bit 3DES
[10:09:23] TLS encrypted session established.
[10:09:23] 4583 bytes transferred. (12,2 Ko/s) (365 ms)
[10:09:23] 226 Directory send OK.
