Crash when changing a file, that was previously monitored
hardipe
Post by hardipe » Thu May 14, 2009 1:44 pm
Seems to be the same as:
https://www.smartftp.com/forums/Crash-on ... 16088.html
a way to reproduce:
start with an empty TrQ
add a file and immediately put it into Monitoring state.
delete the file from the TrQ
change the file's contents
crashes
Re: Crash when changing a file, that was previously monitored
Post by mb » Thu May 14, 2009 3:12 pm
Is the queue stopped before you change the file to monitoring?
hardipe
Post by hardipe » Fri May 15, 2009 12:35 pm
no, it's paused, then the file is added, it's changed to monitoring and then the queue is started
Post by mb » Sun May 17, 2009 11:02 am
Bug fixed. The bug fix will be included in tomorrow's version.
Thanks for reporting.
hardipe
Post by hardipe » Mon May 18, 2009 3:23 pm
thanks for fixing
Post by mb » Tue May 19, 2009 11:06 pm
The new version with the bug fix is available now:
Thanks for reporting this issue.
