Transfer problems
rstearns
Transfer problems
Post by rstearns » Tue Dec 16, 2008 7:15 pm
Since I upgraded to the latest version, I can't transfer. This worked fine last week before the upgrade.
I've tried this to multiple remote systems with the same result. I've checked authority on the remote system and it is not an issue, and as I indicated this worked fine last week before the upgrade.
Here's the requested information:
1. System Information from the menu: Help->About "System Information" dialog
Service Pack 3 (Build 2600)
CPU Speed : 1729 MHz
Total Memory : 1014 MB
Free Memory : 282 MB
Version : 3.0.1024.32
Time Stamp : 2008-11-23 16:59:11
Days in use : 202
sfFTPLib.dll : 1.5.15.6
sfFavorites.dll : 1.0.20.32
sfFavoritesShellExtension.dll : 1.0.1.22
sfTransferQueue.dll : 1.0.17.32
sfFTPShellExtension.dll : 1.0.15.32
SmartFTPPS.dll : 3.0.1024.32
SmartFTP.exe : 3.0.1024.32
Version : 7.0.5730.11
2. Log from the Remote Browser AND the Transfer Queue:
[09:43:57] 250 List completed.
[09:43:57] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[09:44:40] TYPE I
[09:44:40] 200 Representation type is binary IMAGE.
[09:44:40] SIZE 5Gillnet.csv
[09:44:40] 500 Subcommand SIZE not valid.
[09:44:40] MDTM 5Gillnet.csv
[09:44:40] 500 Subcommand MDTM not valid.
[09:44:40] CWD /www/SeaMar/5Gillnet.csv
[09:44:40] 550-Specified directory does not exist or cannot be accessed.
[09:44:41] 550 Working directory not changed.
[09:44:41] TYPE A
[09:44:41] 200 Representation type is ASCII nonprint.
[09:44:41] Ignoring LIST options.
[09:44:41] PASV
3. If applicable please provide a screenshot showing the Remote Browser and the Transfer Queue:
I'll add the image shortly
Re: Transfer problems
Post by mb » Tue Dec 16, 2008 7:39 pm
The log from the transfer queue looks incomplete. Can you please post the complete one?
Also please install the latest version from here:
rstearns
Post by rstearns » Tue Dec 16, 2008 8:02 pm
I reloaded from your beta link
Rebooted
started the transfer again and here is the log:
[11:56:04] SmartFTP v3.0.1025.12
[11:56:09] Resolving host name "172.16.101.11"
[11:56:09] Connecting to 172.16.101.11 Port: 21
[11:56:30] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
[11:56:30] Connect failed. Waiting to retry (30s)...
[11:56:30] Client closed the connection.
[11:56:30] Active Help: https://www.smartftp.com/support/kb/58
[11:57:00] Connection attempt 2...
[11:57:00] Resolving host name "172.16.101.11"
[11:57:00] Connecting to 172.16.101.11 Port: 21
[11:57:00] Connected to 172.16.101.11.
[11:57:00] 220-QTCP at MIWEST.
[11:57:01] 220 Connection will close if idle more than 5 minutes.
[11:57:01] USER qsecofr
[11:57:01] 331 Enter password.
[11:57:01] PASS (hidden)
[11:57:01] 230 QSECOFR logged on.
[11:57:01] SYST
[11:57:01] 215 OS/400 is the remote operating system. The TCP/IP version is "V5R4M0".
[11:57:01] Detected Server Type: AS400
[11:57:01] RTT: 34.952 ms
[11:57:01] FEAT
[11:57:01] 211-Feature listing follows:
[11:57:01] AUTH TLS
[11:57:01] CCC
[11:57:01] PBSZ
[11:57:01] PROT
[11:57:01] 211 End of feature listing.
[11:57:01] TYPE I
[11:57:01] 200 Representation type is binary IMAGE.
[11:57:01] REST 0
[11:57:02] 500 subcommand is only allowed for block or compressed modes.
[11:57:02] PWD
[11:57:02] 257 "QGPL" is current library.
[11:57:02] CWD /www
[11:57:02] 250-NAMEFMT set to 1.
[11:57:02] 250 "/www" is current directory.
[11:57:02] PWD
[11:57:02] 257 "/www" is current directory.
[11:57:02] TYPE A
[11:57:02] 200 Representation type is ASCII nonprint.
[11:57:02] Ignoring LIST options.
[11:57:02] PASV
[11:57:02] 227 Entering Passive Mode (172,16,101,11,107,180).
[11:57:02] Opening data connection to 172.16.101.11 Port: 27572
[11:57:02] LIST
[11:57:02] 125 List started.
[11:57:02] 701 bytes transferred. (3.66 KB/s) (187 ms)
[11:57:02] 250 List completed.
[11:57:08] CWD /www/SeaMar
[11:57:08] 250 "/www/SeaMar" is current directory.
[11:57:08] PWD
[11:57:08] 257 "/www/SeaMar" is current directory.
[11:57:08] Ignoring LIST options.
[11:57:08] PASV
[11:57:08] 227 Entering Passive Mode (172,16,101,11,142,108).
[11:57:08] Opening data connection to 172.16.101.11 Port: 36460
[11:57:08] LIST
[11:57:08] 125 No files found in directory /www/SeaMar
[11:57:08] 0 bytes transferred. (0 bytes/s) (93 ms)
[11:57:08] 250 List completed.
[11:57:17] TYPE I
[11:57:17] 200 Representation type is binary IMAGE.
[11:57:17] SIZE 5Gillnet.csv
[11:57:17] 500 Subcommand SIZE not valid.
[11:57:17] MDTM 5Gillnet.csv
[11:57:17] 500 Subcommand MDTM not valid.
[11:57:17] STAT 5Gillnet.csv
[11:57:17] 504 STAT <file-identifier> not valid.
[11:57:17] CWD /www/SeaMar/5Gillnet.csv
[11:57:17] 550-Specified directory does not exist or cannot be accessed.
[11:57:18] 550 Working directory not changed.
[11:57:18] TYPE A
[11:57:18] 200 Representation type is ASCII nonprint.
[11:57:18] Ignoring LIST options.
[11:57:18] PASV
[11:57:18] 227 Entering Passive Mode (172,16,101,11,171,154).
[11:57:18] Opening data connection to 172.16.101.11 Port: 43930
[11:57:18] LIST
[11:57:18] 125 No files found in directory /www/SeaMar
[11:57:18] 0 bytes transferred. (0 bytes/s) (46 ms)
[11:57:18] 250 List completed.
[11:57:18] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
And the help information is now:
Free Memory : 439 MB
Version : 3.0.1025.12
Time Stamp : 2008-12-16 15:39:10
Days in use : 203
sfFTPLib.dll : 1.5.17.2
sfFavorites.dll : 1.0.21.12
sfFavoritesShellExtension.dll : 2.0.1.6
sfTransferQueue.dll : 1.0.18.12
sfFTPShellExtension.dll : 1.0.16.12
SmartFTPPS.dll : 3.0.1025.12
SmartFTP.exe : 3.0.1025.12
Post by mb » Tue Dec 16, 2008 8:32 pm
Please post the log from the transfer queue. The one you posted is from the remote browser.
rstearns
Post by rstearns » Tue Dec 16, 2008 8:48 pm
[11:57:18] Resolving host name "172.16.101.11"
[11:57:18] Connecting to 172.16.101.11 Port: 21
[11:57:18] Connected to 172.16.101.11.
[11:57:19] 220-QTCP at MIWEST.
[11:57:19] 220 Connection will close if idle more than 5 minutes.
[11:57:19] USER qsecofr
[11:57:19] 331 Enter password.
[11:57:19] PASS (hidden)
[11:57:19] 230 QSECOFR logged on.
[11:57:19] SYST
[11:57:19] 215 OS/400 is the remote operating system. The TCP/IP version is "V5R4M0".
[11:57:19] Detected Server Type: AS400
[11:57:19] RTT: 128.280 ms
[11:57:19] FEAT
[11:57:19] 211-Feature listing follows:
[11:57:19] AUTH TLS
[11:57:19] CCC
[11:57:19] PBSZ
[11:57:19] PROT
[11:57:19] 211 End of feature listing.
[11:57:19] TYPE I
[11:57:19] 200 Representation type is binary IMAGE.
[11:57:19] REST 0
[11:57:19] 500 subcommand is only allowed for block or compressed modes.
[11:57:19] PWD
[11:57:19] 257 "QGPL" is current library.
[11:57:19] CWD www/SeaMar
[11:57:19] 501 Character (/) not allowed in object name.
[11:57:19] Transfer failed.
[11:57:49] CWD www/SeaMar
[11:57:49] 501 Character (/) not allowed in object name.
[11:57:49] Transfer failed.
[11:58:19] CWD www/SeaMar
[11:58:19] 501 Character (/) not allowed in object name.
[11:58:19] Transfer failed.
[11:58:49] CWD www/SeaMar
[11:58:50] 501 Character (/) not allowed in object name.
[11:58:50] Transfer failed.
[11:59:21] CWD www/SeaMar
[11:59:21] 501 Character (/) not allowed in object name.
[11:59:21] Transfer failed.
[11:59:51] CWD www/SeaMar
[11:59:51] 501 Character (/) not allowed in object name.
[11:59:51] Transfer failed.
[12:00:21] CWD www/SeaMar
[12:00:21] 501 Character (/) not allowed in object name.
[12:00:21] Transfer failed.
[12:00:51] CWD www/SeaMar
[12:00:51] 501 Character (/) not allowed in object name.
[12:00:51] Transfer failed.
[12:01:21] CWD www/SeaMar
[12:01:21] 501 Character (/) not allowed in object name.
[12:01:21] Transfer failed.
[12:01:51] CWD www/SeaMar
[12:01:51] 501 Character (/) not allowed in object name.
[12:01:51] Transfer failed.
[12:02:21] CWD www/SeaMar
[12:02:21] 501 Character (/) not allowed in object name.
[12:02:21] Transfer failed.
[12:02:21] Max retry (11 of 10) reached.
Post by mb » Tue Dec 16, 2008 9:57 pm
Can you try it again wih the new version (.16)? It includes a workaround for AS400:
And can you also try to download a file from the library filesystem?
rstearns
Post by rstearns » Tue Dec 16, 2008 10:23 pm
rstearns
Post by rstearns » Tue Dec 16, 2008 10:57 pm
Perfect.
I tested up and down to the IFS (unix/windows files system)
I tested up and down to the QSYS.LIB (native file system)
Thanks for the help
Post by mb » Tue Dec 16, 2008 11:00 pm
Ah thank you for your feedback. If you have any chance can you post the log from the transfer queue downloading a file from QSYS.LIB?
Thanks ;-)
