Map Remote Folder Structure to Local Folder structure
psybert
Post by psybert » Mon Aug 18, 2008 2:31 am
For instance... Say you have a remote site directory
with sitename.com
underneath you have a folder structure
/images/
/code/
etc.
I would like to be able to map that remote directory to follow the same folder structure on my PC.
so I would have a folder
d:\projects\sitename.com\
and under it would have
/images/
/code/
etc.
So when I'm navigating either directory (remote or local) the other would follow along and stay in the same directory.
I hope that makes sense ?
I know that many people would be interested in something like this.
Thanks!
Re: Map Remote Folder Structure to Local Folder structure
Post by mb » Mon Aug 18, 2008 2:44 am
The feature is implemented and it's called "Sync Navigation". To activate it open a Local Browser and a Remote Browser. Select the root folders in both browser and then press the "Sync Navigation" button in the toolbar between the two browsers.
psybert
Post by psybert » Wed Aug 20, 2008 12:30 am
That's great. Thanks for the tip.
It would also be nice to "lock it in", so you would basically set a local root directory to map directly to a remote root directory, so when you're working with different sites/local/remote browsers, smartFTP could figure out the mappings and change itself accordingly.
I understand that would probably be a ton of work, but maybe something to think about.
psybert
Post by psybert » Wed Aug 20, 2008 2:32 am
Also, if they sorted together, that would be great too
