MDTM - 502 command not implemented
colby
Post by colby » Tue Jul 15, 2008 7:25 am
I can not upload a file because of the MDTM error
Please help.
[02:15:50] SmartFTP v3.0.1015.5
[02:15:50] Resolving host name "secureftp.peachtreedata.com"
[02:15:51] Connecting to 66.187.183.244 Port: 21
[02:15:51] Connected to secureftp.peachtreedata.com.
[02:15:51] 220-Security Notice
[02:15:51] 220-You are about to access a secured resource. Unauthorized access is
[02:15:51] 220-prohibited.
[02:15:51] 220-Peachtree Data, Inc. reserves the right to monitor and/or limit access
[02:15:51] 220 to this resource at any time.
[02:15:51] AUTH TLS
[02:15:51] 234 SSL enabled start the negotiation
[02:15:51] Connected. Exchanging encryption keys...
[02:15:52] Session Cipher: 128 bit RC4
[02:16:07] TLS encrypted session established.
[02:16:07] PBSZ 0
[02:16:07] 200 PBSZ command successful
[02:16:07] USER res020
[02:16:07] 331 Password required for res020
[02:16:07] PASS (hidden)
[02:16:07] 230-Welcome to Peachtree Data's SecureFTP server!
[02:16:07] 230-If you have any questions please contact us at 678-987-4600.
[02:16:08] 230-All time and date stamps displayed on this site are GMT -4, except time and date stamps recorded during standard time (GMT -5).
[02:16:08] 230-This server is configured to do passive mode transfers only.
[02:16:08] 230 User res020 logged in.
[02:16:08] SYST
[02:16:08] 215 Windows_NT version 5.0 (MOVEit DMZ FTP 5.5.0.0)
[02:16:08] Detected Server Type: Windows NT
[02:16:08] Detected Server Software: MOVEit
[02:16:08] FEAT
[02:16:08] 211-Extensions supported:
[02:16:08] AUTH SSL
[02:16:08] AUTH TLS-P
[02:16:08] AUTH TLS
[02:16:08] AUTH TLS-C
[02:16:08] PROT
[02:16:08] PBSZ
[02:16:08] SIZE
[02:16:08] REST STREAM
[02:16:08] MODE Z
[02:16:08] XSHA1
[02:16:08] INTEGRITY
[02:16:08] HASH
[02:16:08] CLNT
[02:16:08] 211 End of list
[02:16:08] CLNT SmartFTP 3.0.1015.5
[02:16:08] 213 "SmartFTP 3.0.1015.5" noted.
[02:16:08] PWD
[02:16:08] 257 "/Home/res020" is current directory
[02:16:09] CWD /Home/res020/Download
[02:16:09] 250 CWD command successful
[02:16:09] PWD
[02:16:09] 257 "/Home/res020/Download" is current directory
[02:16:09] TYPE A
[02:16:09] 200 TYPE command successful
[02:16:09] MODE Z
[02:16:09] 200 MODE Z ok
[02:16:09] PROT P
[02:16:09] 200 PROT command successful
[02:16:09] PASV
[02:16:09] 227 Entering Passive Mode (66,187,183,244,11,208)
[02:16:09] Opening data connection to 66.187.183.244 Port: 3024
[02:16:09] LIST -aL
[02:16:09] Connected. Exchanging encryption keys...
[02:16:09] 150 Opening ASCII mode data connection
[02:16:10] Session Cipher: 128 bit RC4
[02:16:10] TLS encrypted session established.
[02:16:10] 0 bytes transferred. (0 bytes/s) (281 ms)
[02:16:10] 226 Transfer complete
[02:16:38] TYPE I
[02:16:38] 200 TYPE command successful
[02:16:38] SIZE ROG_07142008_1001_P.zip.pgp
[02:16:38] 550 SIZE failed: File could not be found
[02:16:38] MDTM ROG_07142008_1001_P.zip.pgp
[02:16:38] 502 Command not implemented
[02:16:38] TYPE A
[02:16:38] PASV
[02:16:38] 227 Entering Passive Mode (66,187,183,244,11,205)
[02:16:38] Opening data connection to 66.187.183.244 Port: 3021
[02:16:38] LIST -aL
[02:16:39] Connected. Exchanging encryption keys...
[02:16:39] 150 Opening ASCII mode data connection
[02:16:39] Session Cipher: 128 bit RC4
[02:16:39] TLS encrypted session established.
[02:16:39] 0 bytes transferred. (0 bytes/s) (156 ms)
[02:16:39] 226 Transfer complete
[02:16:39] The operation has been added to the Transfer Queue. Check the Transfer Queue for the status.
[02:16:51] STAT ROG_07142008_1001_P.zip.pgp
[02:16:51] 211-SECUREFTP MOVEit DMZ FTP Version 5.5.0.0 status:
[02:16:51] The local time is 2008-07-15 03:16:51.81
[02:16:51] 211 End of status.
[02:16:51] MDTM ROG_07142008_1001_P.zip.pgp
[02:16:51] 502 Command not implemented
[02:17:22] NOOP
[02:17:22] 200 NOOP command successful
[02:17:22] STAT ROG_07142008_1001_P.zip.pgp
[02:17:22] 211-SECUREFTP MOVEit DMZ FTP Version 5.5.0.0 status:
[02:17:22] The local time is 2008-07-15 03:17:22.63
[02:17:22] 211 End of status.
[02:17:22] MDTM ROG_07142008_1001_P.zip.pgp
[02:17:22] 502 Command not implemented
Re: MDTM - 502 command not implemented
Post by mb » Tue Jul 15, 2008 10:47 am
Install the latest version from:
Then post the log from the transfer queue item:
double click the file in the transfer queue (bottom window) that doesnt process to get the log. Then post the log here.
colby
Post by colby » Wed Jul 16, 2008 2:39 pm
Post by mb » Wed Jul 16, 2008 2:54 pm
Please let me know if you have any further problems and we can assist you. If you would like to know more about network protocols, inter-computer communication and in particular about the FTP protocol I recommend you to take a look at the following pages:
http://en.wikipedia.org/wiki/File_Transfer_Protocol
http://www.w3.org/Protocols/rfc959/
http://www.windowsnetworking.com/articl ... tocol.html
http://www.cs.rpi.edu/academics/courses ... /html/ftp/
