Version Portable
foupoudave
Version Portable
Post by foupoudave » Sun Mar 23, 2008 1:11 pm
Grieved for my English, I speak very badly English. I therefore used a translator.
Archive offered to return SmartFTP in portable version is not compatible any more in new version.
Re: Version Portable
Post by mb » Mon Mar 24, 2008 4:28 am
You can get the updated version from:
However I didn't test it and I do not recommend to use the portable wrapper. The source is included in case you want to do some testing.
foupoudave
Post by foupoudave » Mon Mar 24, 2008 2:43 pm
Post by mb » Mon Mar 24, 2008 2:53 pm
My bad. Please try it again with the updated version.
foupoudave
Post by foupoudave » Tue Mar 25, 2008 6:44 pm
Thank you. I do not have problem anymore. Bravo for your reactivity!
Joyce
Post by Joyce » Mon Apr 28, 2008 7:15 pm
PortableSmartFTP.exe works fine. But when I try to compile the autoitscript, the resulting exe doesn't work (The Favorites are being loaded from %Application Data% folder. Can you plz provide the source file of the updated exe? I want to make SmartFTP compatible with PortableApps. Presently all the exe files (PortableSmartFTP.exe, SmartFTP.exe and BackupTool.exe) appear in the Portable Apps Menu.
Post by mb » Mon Apr 28, 2008 7:29 pm
The executable matches the included source file.
Joyce
Post by Joyce » Mon Apr 28, 2008 8:03 pm
Thanks for the quick response.
My compiled exe is 283 kb, while the included exe is 315 kb. Can you plz tell me the version of AutoIt you are using?
Joyce
Post by Joyce » Tue Apr 29, 2008 3:10 pm
I was using an older version of AutoIt. I updated to the latest version and now everything is working fine. Thanks for the great program and help.
Mattik
Post by Mattik » Fri Jun 20, 2008 1:29 pm
The updated version shows:
Fatal Error: sfFavorites.dll is not registered correctly
Some new version available?
