Show Raw Listing opens blank Notepad
timbrummitt
Post by timbrummitt » Mon Feb 04, 2008 10:58 am
When I use the Show Raw Listing command it opens a blank version of Notepad with no listing. Occasionally, there is a Notepad pop-up notification "Cannot find the .txt file. Do you want to create a new one?". I am using SmartFTP 2.5 and have tried restart, uninstall/reinstall and installing the version 3 beta but get the same problem. I have tried Raw Listing on two remote servers where I have accounts and on public servers such as ftp://ftp.uu.net. A typical log entry when connected to ftp://ftp.uu.net is:
[10:51:15] Opening data connection to 192.48.96.9 Port: 61516
[10:51:15] LIST
[10:51:15] 412 bytes transferred. (3.21 KB/s) (125 ms)
[10:51:15] 150 Opening ASCII mode data connection for /bin/ls.
[10:51:16] 226 Transfer complete.
I have also tried changing the List Arguments in the Favourites > Properties > Transfer
My SmartFTP System Info is shown below.
Regards
timb
Service Pack 2 (Build 2600)
CPU Speed : 1599 MHz
Total Memory : 494 MB
Free Memory : 46 MB
Version : 2.5.1008.37
Time Stamp : 2008-02-01 00:10:32
sfFTPLib.dll : 1.5.12.13
sfFavorites.dll : 1.0.4.37
sfFavoritesShellExtension.dll : 1.0.1.5
sfTransferQueue.dll : 1.0.1.37
SmartHook.dll : 1.0.2.2
SmartFTP.exe : 2.5.1008.37
Version : 6.0.2900.2180
Re: Show Raw Listing opens blank Notepad
Post by mb » Mon Feb 04, 2008 12:39 pm
Hm I can't reproduce it. What's the full path to your temporary folder?
For example on my Vista system its:
C:\Users\mb\AppData\Local\Temp
timbrummitt
Post by timbrummitt » Mon Feb 04, 2008 3:32 pm
Good idea. My temporary folder is at C:\Documents and Settings\Tim\Local Settings\Temp. A .tmp file such as "sf117.tmp" is being written to this folder after a "Show Raw Listing" and it does seem to have the correct info. I have copied an example of a listing of a directory containing six image files at the end of this note.
I still get a blank Notepad even though I have made Notepad the default for .tmp files. Do I just have to put up with this and manually open the .tmp file in the Temp folder as a workaround?
Thanks for your help
Tim
type=cdir;sizd=4096;modify=20080202114850;UNIX.mode=0755;UNIX.uid=32165;UNIX.gid
=32168;unique=808g934056; .
type=pdir;sizd=4096;modify=20080202114620;UNIX.mode=0755;UNIX.uid=32165;UNIX.gid
=32168;unique=808g934040; ..
type=file;size=1400;modify=20080202114848;UNIX.mode=0644;UNIX.uid=32165;UNIX.gid
type=file;size=1264;modify=20080202114848;UNIX.mode=0644;UNIX.uid=32165;UNIX.gid
type=file;size=1504;modify=20080202114849;UNIX.mode=0644;UNIX.uid=32165;UNIX.gid
type=file;size=6837;modify=20080202114849;UNIX.mode=0644;UNIX.uid=32165;UNIX.gid
type=file;size=828;modify=20080202114850;UNIX.mode=0644;UNIX.uid=32165;UNIX.gid=
type=file;size=43;modify=20080202114850;UNIX.mode=0644;UNIX.uid=32165;UNIX.gid=3
Post by mb » Mon Feb 04, 2008 7:19 pm
Version 3.0 beta uses a .txt file extension instead of the .tmp extension. Also I have back ported the changes to version 2.0. The next build of 2.0 will include the fix.
Thank you for your feedback.
