Keyboard Hot Keys not working
intelx86
Post by intelx86 » Fri Aug 10, 2007 1:32 pm
I own the Microsoft Internet Keyboard. While working with SmartFTP, I cannot use hot keys such as My computer or Calculator, which is very handy.
Note: The keys are working with other applications
Re: Keyboard Hot Keys not working
Post by mb » Fri Aug 10, 2007 10:02 pm
Thank you for reporting this bug. Unfortunately I don't have a keyboard with any specials keys to test it. Thats why I have to ask you to try the following sample application:
http://www.codejock.com/public/download/win32/Pane.zip
If it doesn't work then it's a problem with the GUI framework we use.
intelx86
Post by intelx86 » Sat Aug 11, 2007 8:11 am
I tested the sample. The hot keys are working while I am writing for example in a TextBox.
Post by mb » Sat Aug 11, 2007 11:55 am
In the meanwhile we have tested the latest version of SmartFTP on Windows XP with a Microsoft Intelitype Pro keyboard but we didn't see any problems.
In SmartFTP you cannot use them in any case - regardless where the focus is?
intelx86
Post by intelx86 » Sat Aug 11, 2007 2:56 pm
I cannot use them in the main form. While managing favorites, viewing the About form hot keys work.
Note: I have not installed IntelliType
Post by mb » Sat Aug 11, 2007 4:54 pm
Please make a list of controls where the hot keys don't work. Do you have a Local Browser open/focused? Is a Remote Browser open/focused?
intelx86
Post by intelx86 » Sat Aug 11, 2007 5:02 pm
remote browser (folder View & folder list listboxes)
Log textbox
Transfer queue Listbox
Temporary queue listbox
connections listbox
speed pane
username & password textboxes
server url dropdown
location dropdown
port textbox
The problem occurs on Windows XP SP2 and Windows Vista.
Post by mb » Sat Aug 11, 2007 5:07 pm
Therefore it works in the Local Browser?
intelx86
Post by intelx86 » Sat Aug 11, 2007 5:10 pm
neither in local browser controls
Post by mb » Sun Aug 12, 2007 10:26 pm
What theme are you using in SmartFTP? Settings -> Interface. Does it make a difference if you use a different theme?
