CPU usage way high
ender
CPU usage way high
Post by ender » Tue Mar 27, 2007 11:12 am
This is something i noticed recently, not sure if it has anything to do with the new upgrade i put in from 2.0 to the latest.... But i have about 1000 images on download queue and my CPU processes shows SmartFTP as taking 48% of my CPU. As soon as i stop the queue the CPU goes back down to nearly nothing as it should be. Why does SmartFTp take up so much juice?
Service Pack 2 (Build 2600)
CPU Speed : 2798 MHz
Total Memory : 1023 MB
Free Memory : 390 MB
Version : 2.5.1005.3
Time Stamp : 2007-03-23 22:41:08
sfFTPLib.dll : 1.5.9.12
SmartHook.dll : 1.0.2.1
SmartFTP.exe : 2.5.1005.3
shell32.dll : 6.00.2900.3051 (xpsp_sp2_gdr.061219-0316)
shlwapi.dll : 6.00.2900.3059 (xpsp_sp2_gdr.070104-0050)
comctl32.dll : 6.0 (xpsp.060825-0040)
riched20.dll : 5.30.23.1228
schannel.dll : 5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)
Version : 6.0.2900.2180
ender
Re: CPU usage way high
Post by ender » Tue Mar 27, 2007 4:07 pm
This is what i found out how to reproduce it.
I like to have 5 workers set in the queue, not all 5 work of course because some site i only allow 1 worker. but I want to be able to transfer 5 times from different sites.
Givens:
On a per site basis:
- 1 worker allowed to download with 1 worker to view only.
- An occasional will have 2 or 3 workers, but generally since i download from home users I set the worker to 1
- I set the number of workers in the queue to 5, allowing me to download 5 times from 5 different sites if i need to, but usually it is 1 or 2.
- If i am on 2 sites, and set the workers to 5 the CPU jumps to nearly 50%. If i reduce it to the 2 connections, then the memory drops back to 5-6% as normal. So far as i know, i should be able to keep the workers at 5, leaving 3 available should i want to connect to a different site. This is reproducible all the time.
EDIT: under options/queue it is set to 2 the last number i set it before the cpu usage goes to 47%, but when i restart the application, it still says 2, but in the queue pane it says 1. Not consistent.
I also updated to the latest version
- As a test I reinstalled version 2.0.1000.0 and redid my queue and all my problems go away. If i have 5 workers, the program says i have 5 even after restarting the program. it does not revert back to 1. Also my CPU will remain below 10% with 5 workers and 3 active. So the problem is somewhere with the v2.5 install.
Free Memory : 439 MB
Version : 2.5.1005.5
Time Stamp : 2007-03-27 04:28:24
SmartFTP.exe : 2.5.1005.5
Post by mb » Wed Mar 28, 2007 9:55 am
Please test it again with the latest version (.6). I have fixed the inconsistency of the "Max Workers" setting.
The high CPU problem is related to the fact that SmartFTP scans (previously every 200 ms) all items in the Transfer Queue to see if it can start a new worker. But as all items have the same Favorite with the Max Worker limit set to 1 it won't be able start anything. I have increased the scan interval to 1s now.
ender
Post by ender » Wed Mar 28, 2007 10:46 am
That is better, the queue remains with 5 workers and no longer reverts back to 1 every time i restart the application. The CPU usage of Smart FTP fluctuates now between 13% and 30% according to task manager. I still think this is too high and when I did my test yesterday with 2.0.1000.0, it never went above 10%
What i noticed as well, and it could be just me, I dunno... If i am connected to only one site with 1 worker out of 5 (with approx 15 files and 5 folders in queue), the CPU % of SmartFTP sticks around 10-11%. As soon as I connect to a 2nd site, and if that site has a ton of files, the CPU seems to jump around quite a bit. If that 2nd site only has one or 2 files, the CPU% remains pretty constant. Again, this is just something i noticed. Could be nothing, i don't know.
Thanks for the quick response on the fix .... Keep up the great work!
Post by mb » Tue Apr 10, 2007 6:55 am
The latest version addresses this problem.
Bruno
Post by Bruno » Tue Apr 10, 2007 8:37 am
Ihr k
csawjer
Post by csawjer » Wed Jun 20, 2007 9:13 am
I notice on my laptop even worse problems with CPU load going to 100%. This happens if directories with large number of files are transferred (>40). Then the system hangs and there is no remedy other than killing the tasks. Sometimes even that does not work!
