SmartFTP in French !
jerebat
Post by jerebat » Wed Nov 07, 2001 1:13 am
I would like to inform you that a french translation is available on http://jerebat.cjb.net/. I try to update this translation as often as possible.
Je voudrais vous informer qu'une traduction fran
Re: SmartFTP in French !
Post by mb » Thu Nov 08, 2001 12:13 am
Okay ... At first I say thanks.
BUT ... the problem is that localizations are only working for the version and build they are made for. To have updated localizations I really encourage you to work with the developers of SmartFTP.
We'll offer you as much help as you need to keep the localization up to date. We even provide you an FTP account so you can directly update your pages on smartftp.com.
Thanks a lot
teenage
Post by teenage » Fri Nov 23, 2001 3:26 pm
I try this localization : It turn smartftp into a useless piece of software : menus don't roll down, icones disappear when you try to click on them, smartftp window freeze,...
Sorry jerebat, but your translation still got some bugs.
My conf : PC 800Mhz, 128mo, 20Go, win98se, smartftp v1.0 build 963
Jerebat soft : SmartFTP_1_0_963_FR.exe
Allez Jerebat tu peux mieux faire :-)
teenage
Post by teenage » Wed Nov 28, 2001 10:34 am
Ok, the french translation finally work : the computer has to be started again...
D
jerebat
Post by jerebat » Fri Dec 07, 2001 3:40 pm
Y'a pas de mal, je ne viens pas tr
