LoadLicenseKeyData returns FALSE ?!
uksbi
Post by uksbi » Wed Aug 02, 2006 6:46 pm
we updated our dll to version 1.5.8.18. Now the following code returns FALSE ...
Public objGlobal As sfFTPLib.Global
Set objGlobal = CreateObject("sfFTPLib.Global")
If objGlobal.LoadLicenseKeyData(strKey) = True Then
	Debug.Print "+ INFO ... SmartFTP Registrierung ... OK"
  Else
	Debug.Print "+ ERROR ... SmartFTP nicht registriert"
End If
Is it a problem of our license or is it a bug. The version before update was 1.5.8.12
The rest of the code to transfer the data works fine.
THX for help ... Ulf
Re: LoadLicenseKeyData returns FALSE ?!
Post by mb » Wed Aug 02, 2006 8:14 pm
Dear Ulf ..
The maintenance of your license key expired. It means that you need to renew your license key if you want to use a version of the SmartFTP FTP Library which has been released after the maintenance expiration date in your license key.
You can renew your license key here:
https://www.smartftp.com/purchase/renew.php
