"broken pipe" - error - then doesn't connect
dfstone
Post by dfstone » Thu Jun 29, 2006 11:39 pm
I am having a problem with a "broken pipe" - error - then doesn't connect to the server.
used to work fine eveyday. now it takes more than 20 seconds trying to connect then logs a
"broken pipe" - error - then doesn't connect.
what is happening?
thank you.
dfstone
Re: "broken pipe" - error - then doesn't connect
Post by dfstone » Fri Jun 30, 2006 2:00 pm
[06:43:54] Transfer Timeout (40s). Closing data connection.
[06:43:54] 31655 bytes transferred. (758 bytes/s) (00:00:41)
[06:43:55] 451 Transfer aborted. Broken pipe
some one help please?
Mike
Post by Mike » Fri Jun 30, 2006 4:18 pm
Your server closes the connection while a transfer is in progress and you can do nothing from the client site, talk to your server admin to find out what is wrong with the server.
dfstone
Post by dfstone » Fri Jun 30, 2006 5:54 pm
thank you Mike!
Post by mb » Sun Jul 02, 2006 8:44 am
The user reported his problem has been fixed by changing the data transfer method from passive mode to active mode.
