no folders, no files
henry
Post by henry » Sun Mar 19, 2006 7:42 pm
Sorry for another posting with this title, but I searched now for several hours and none of the solutions I found worked for me.
If I connect to a server of a friend, no folders or files are shown. I can manually change into one directory, but still no files are shown. I can uplaod files to the server, but they are not shown in SmartFTP.
Changing the 'directory listing options' in settings - transfer doesn't show any effect, it makes no difference if none or any combination of them are enabled or disabled.
I reinstalled SmartFTP, without a change.
I have no problems by connecting with a browser or an older version of WS-FTP.
Here is my raw listing:
drw-r--r--  2 0		0		4096  Mar  7 18:27 Share
-rw-r--r--  1 0		0		0  Feb 28 13:19 time_status
drw-r--r--  3 0		0		4096  Feb 25 04:03 HTML
drw-r--r--  2 0		0		4096  Feb 28 13:18 DATA
drw-r--r--  2 0		0		4096  Feb 23 15:08 Scripts
drw-r--r--  3 0		0		4096  Mar  1 13:10 toddi
and my log:
[20:37:10] SmartFTP v2.0.995.16
[20:37:11] Resolving host name "xxxxx.net"
[20:37:11] Connecting to xxx.xxx.xxx.xxx Port: 21
[20:37:11] Connected to xxxxx.net.
[20:37:11] 220 SERVER FTP server ready.
[20:37:11] USER xxxxx
[20:37:11] 331 Password required for xxxxx.
[20:37:11] PASS (hidden)
[20:37:11] 230 User xxxxx logged in.
[20:37:11] SYST
[20:37:11] 215 UNIX Type: L8
[20:37:11] FEAT
[20:37:11] 500 'FEAT': command not understood.
[20:37:11] TYPE I
[20:37:11] 200 Type set to I.
[20:37:11] REST 0
[20:37:11] 350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer.
[20:37:11] PWD
[20:37:11] 257 "/" is current directory.
[20:37:15] TYPE A
[20:37:15] 200 Type set to A.
[20:37:15] PASV
[20:37:15] 227 Entering Passive Mode (xxx,xxx,xxx,xxx,4,129)
[20:37:15] Opening data connection to xxx.xxx.xxx.xxx Port: 1153
[20:37:15] LIST
[20:37:15] 150 Opening ASCII mode data connection for 'file list'.
[20:37:15] 524 bytes transferred. (17,0 KB/s) (30 ms)
[20:37:15] 226 Transfer complete.
Any ideas?
Re: no folders, no files
Post by mb » Mon Mar 20, 2006 12:30 pm
Please test it with the latest version from:
Do you know by any chance what FTP server software is running on the server?
henry
Post by henry » Mon Mar 20, 2006 8:09 pm
Jep, with the version from the link it's working, also with the 'directory listing options' enabled.
And no, I don't know what server software is running on the server. It's some kind of a Linux OS, but that's all I can say. Why are you asking, could there be some incompatibilties with any server software or what?
And what are the differences between the beta version and the final? Can I use the beta without any risks or are there some security or other problems?
Post by mb » Mon Mar 20, 2006 10:45 pm
The version available now is final.
kthardin
Post by kthardin » Wed Mar 22, 2006 5:26 am
I have a similar problem. I had aquired an old alcatel switch from ebay and was attempting to update its operating system. While I could transfer files to it, I couldn't see any files or folders inside the switch. WS_FTP has no such problems.
As henry did before me, I removed all directory listing options with no effect. I even used the beta version posted with no change.
Any ideas?
Post by mb » Wed Mar 22, 2006 6:04 am
Post the transfer log and the raw directory listing as henry did.
mackal
Post by mackal » Wed Mar 22, 2006 4:03 pm
Post by mb » Wed Mar 22, 2006 7:40 pm
Aha. Interesting that all these FTP servers running under linux always come up with a slightly different listing format instead of supporting MLSD. I will see that the next version will support the "new" listing format.
kthardin
Post by kthardin » Fri Mar 24, 2006 3:55 am
Post by mb » Fri Mar 24, 2006 7:58 am
We are not planning to support the Alcatel OmniSwitch 6000 device unless you can give us a good reason.
