Resend login details without disconnect?
Craig
Post by Craig » Mon Feb 27, 2006 8:21 pm
I'm having trouble with the following sequence of steps:
1) Set up the FTP connection as necessary, with an invalid username or password
2) Call Connect()
3) Catch the 500/530 error and update the username and password to correct values
4) Goto 2
As written the second Connect() call returns ftpErrorNotDisconnected. If I add a call to Disconnect() after step 3 then it works correctly, but that doesn't seem like it should be necessary. Is this an intentional limitation?
Craig
Re: Resend login details without disconnect?
Post by mb » Mon Feb 27, 2006 9:16 pm
Yes this is a limitation. A lot of FTP servers automatically close the connection if the authentication fails anyway. It's safer to restart with the complete connect/login sequence.
