Development Status:EOL
2.0.1002.1 - 22. January 2007
- Added dynamic timeout for server side hash calculation (XMD5, etc).
- Transfer Queue: Fixed FXP of directories.
- Transfer Queue: Added import of URL lists (Text file with 1 URL per line). Use the Add button in the "Transfer Queue" pane.
- Enabled move operation for Drag&Drop to Local Browser / Windows Explorer / Desktop.
- Transfer Queue: Added import of legacy transfer queue files (.que, .dat) and metalink files (.metalink).
- Full support for Copy/Paste/Cut in the Remote Browser and Transfer Queue.
- The local file time is set for aborted/failed downloads
- Transfer Queue: Fixed a bug when monitoring more than 1 file in a folder
- Cut/Paste from Local Browser to Remote Browser with default Drag&Drop operation set to Queue will result in a move operation
- Fixed various bugs introduced in previous beta versions
- Fixed a bug with the Filters
- Major internal refactoring
- Fixed a crash introduced in 2.0.1001.5
- Internal changes
- Fixed: Some problems with the latest GUI update
- Internal unspecified changes
- Added support for AS/400 with LISTFMT set to 1 (unix)
- Transfer Queue: Added recurrence for start/stop timers
- Updated GUI library. New MDI tab navigation (Ctrl+Tab)
- Moved history entries from History.dat to registry
- Transfer Queue: Using faster event handlers with less overhead for queue items. This may partly fix the memory leaks from OLE.
- Added case sensitive options to the Settings -> Transfer -> Filters
- All filters (Selection Groups, Ascii Files, Compression and Transfer Filters) are case insensitive now
- Settings -> Transfer -> Filters now support two modes (Include or Exclude mode)
- Fixed: Layout of panes didn't save correctly on close
- Added partial support for drag&drop move operation (Transfer Queue only)
- Compilation with new VS 2005 SP1.
- Some small changes to UPnP.
- Local Browser: Using new Shell Tree Control under Windows Vista.
- Fixed: Local Browser crash on Windows Vista.
- Fixed Enter key in Remote Browser.
- Fixed bug where SmartFTP would stop working correctly after the 10. November.
- Added Menu: Window -> Reset Docking Pane Layout function to restore "lost" panes when using a multiple monitor configuration
- Favorites: Added import of "FTP Voyager CSV" exported site files.
- Fix: Import of URL List (.txt)
- Added support to import FTP Voyager 13.x site files.
- Remote Browser: Added asynchronous cleanup/close of Remote Browser.
- Remote Browser: Added tooltip in the edit box for invalid characters.
- Added 256x256 icon for Windows Vista.
- Fixed dead lock when an URL is copied to the clipboard before SmartFTP is started and then added to the queue.
- Local Browser: Fixed right-click on ZIP files.
- Remote Browser: Directory wasn't automatically refreshed after upload.
- Transfer Queue: Retry information shows time now.
- Local Browser: Zip files are now displayed in the tree (same behavior as Windows Explorer). If you want to system wide disable .zip file support in Windows Explorer run the following command:
regsvr32 /s /u %windir%\system32\zipfldr.dll - Local Browser: For better performance icons are obtained asynchronously in the tree control
- Fix for occasional crash on exit if Ident server was enabled.
- Workaround for race condition in the MFC code.
- Added "Exclusion Filters" to the Favorite Item Settings.
- Added "Enable Filter" to Settings -> Transfer -> Filters.
- Transfer Queue: Fixed retry delay.
- Transfer Queue: Better retry delay handling.
- Custom Commands: Fixed memory caused by multiline custom commands
- Custom Commands: Fixed %lf
- Transfer Queue: New strategy for "Move" and "Delete Recursive" operations.
- Transfer Queue: Fixed Recurrence.
- Local Browser: Fixed crash if a URL is entered into the path combo box
- New: Transfer Queue: Added "Delete Recursive" operation.
- New: Local Browser: Added Open (Enter) and View menu functions.
- IMPORTANT: Schedule Recurrence is broken!
- New: Transfer Queue: Multi Item Edit Dialog.
- New: Transfer Queue: Changed Single Item Edit Dialog to change Source/Destination type.
- Added key shortcuts:
F4: Opens history list (was F6 previously)
Ctrl+G: Go
Shift+Ctr+L: Opens new Local Browser and goes to the local directory if defined in the favorite item
Ctrl+L: Opens new Local Browser
Alt+Left Arrow: Go back
Alt+Right Arrow or Backspace: Go forward
Enter: Open selected file (was F4 previously)
- Fixed: Transfer Queue was showing negative values for Total Size.
- Added: "Move" operation for Transfer Queue.
- Fixed: Transfer Queue Auto Stop/Auto Start (Timer).
- Fixed: Transfer Queue Auto Dialer once enabled was always enabled.
- Fixed: Number of Workers per Favorite/Site limit.
- Fixed: Favorite/Site based retry delay if connection or login to server failed.
- Fixed: Items weren't sorted when added to the Transfer Queue.
- Fixed: Progress bar in Remote Browser (broken since .16).
- Fixed: "Connections" pane for Transfer Queue connections. Number of uploads/downloads in scrolling text when SmartFTP is minimized.
- Fixed: Secured Downloads (SSL/TLS) with Speed Limits.
- Fixed: Crash if the Settings->Interface "Size" option was set to "Bytes" and files > 1GB were added to the transfer queue.
- Fixed: Bug in transfer queue where the state of failed items could be set to aborted in certain situations.
- Added hybrid path (VMS/Unix) support for OpenVMS.
- Removed [x] Ignore File Version option in the Settings -> Interface -> Language dialog
- Fixed: Bug if the [ ] Reuse connection option was disabled in the Transfer Queue.
- Transfer Queue: Split up "Speed" column into "Average Speed" and "Current Speed" columns.
- Fixed: Recent Time span in File Exist settings was always set to 120s if [x] Use Global Settings was enabled in the favorite item
- Fixed: Problem with move of items in the Transfer Queue list control.
- Fixed: Overflow in the Queue Item Status message in the List Control if more than 1 GB of data is transferred.
- Added file information (time, size) of the source and destination file to the log of a transfer queue item. Useful to debug file exist rules.
- Fixed: Crash handler was broken. No useful information was submitted on crash.
2.0.998.6 - 7. September 2006 (BETA)
- Added "Local to Local" copy in Transfer Queue. Use the "Temporary Queue" to add items to the queue.
- Fix: File Exist "Transfer Condition" was always ignored
- Rewrote "Transfer Queue" back-end. New features include "Remove finished", "Auto Save" options, XML serialization/import and selection of columns in the list control.
- Added: The Upload menu items in the context are now enabled if a single folder is selected in the list control of the Remote Browser.
- Changed: "View" command will ignore "File size mismatch" errors.
- Updated GUI component. Fixes Office 2007 theme for panes.
- Added icons in the Settings and Favorite Properties dialogs.
- Regression: "Auto Column Sizing - By View" algorithm
- Added new option "Show warning if server cert is not trusted" in "Settings->Connection->SSL" dialog.
- Added "Login Type" option for Username/Password less authentication.
- Right-click on column header in Remote Browser's list control allows the selection of the displayed columns.
- Fixed: Issue in the file exist rules where two file times were never considered equal.
- Fixed: Log control didn't redraw correctly.
- Redesigned "Edit Custom Commands" view.
- Added "New File" feature.
- Fixed: States images (up,down,fxp) were not displayed in the Transfer Queue if the pane wasn't selected.
- Fixed: Clicking on an URL in the log had no effect.
- Fixed: Small bug with customization of login bar.
- Changed some strings in the "Edit Custom Commands" dialog.
- Fixed: List control in Local Browser didn't restore View Mode (List, Details, Small Icons, Large Icons) correctly.
- Fixed: When Remote Browsers are restored the favorite item setting General -> Local -> "On Connect" is ignored.
- AS/400: Directory listing parser recognizes more items as directories.
- AS/400: SmartFTP doesn't automatically send a CWD command with a / after the login anymore.
- AS/400 (iSeries): Added new Custom Commands to change the "File Naming Format". You may need to restore the default (Menu: Commands->Edit Custom Commands->Restore Defaults). Also see KB: AS/400 (iSeries)
- Fixed: Dropping items over file items in the Remote Browser was not possible. Also known as "Empty Space" bug.
- Using dot instead of check mark icons in the menu: View->Sorty By
- Added Drag&Drop delay (250ms) for selection of MDI tabs and Docking Panes
- Fixed: Small bug with column sort in the list control of the "Remote Browser".
- Added verification of sfFTPLib.dll
- Set log line hard limit to 1024 to save memory resources.
- Fixed: Upload Directory for FTP servers with a non-UNIX style path.
- Favorites are automatically saved if a new favorite item is added or deleted
- History is automatically updated/synchronized after a favorite item has been deleted
- Fixed: Integrity check was skipped sometimes.
- Added right mouse click drag&drop menu to the shell tree in the Local Browser.
- Fixed: Small problem with the Office 2007 theme.
- Fixed: Time comparison (if time is unknown) in the File Exist rules.
- Internal: Changed the way how the threads in the FTP Library component are started.
- Fixed: Updated GUI component which fixed the "Customize" problem.
- Added tear-off to Workspace menu .
- Added new icons to the Workspace menu
- Fixed: Small redrawing problem with Themes.
- Toolbars can be moved next to the menu bar now
- Added "Stand By" to the On Queue Complete function list.
- Fixed: Bold items for cached folders.
- Fixed: "Close All But This".
- Fixed: Small GDI leak.
- Fixed: Changed some minor things in the dialogs.
- Experimental: Added "Sync Navigation" feature. The button to enable it can be found in the "Quick Transfer" toolbar.
- Fixed: Small buffer overflow in the custom commands code
- Delete works for running queue items.
- Version string is showed in the log of the queue item as well.
- Fixed: Directory in the Backup page didn't save.
- Workspace is no longer restored if an URL has been passed in the command line.
- New command line option: smartftp://GUID/path where GUID is the GUID of the favorite item.
- New shortcuts for Favorites: Menu: Favorites -> Edit Favorites. Then drag&drop or copy&paste a favorite item to the Desktop. A shortcut is created and you can double click to open the server/remote site.
- Fixed: Restore Defaults in "Selection Groups".
- Closing the File Exist Dialog by clicking on the [x] cancels the operation.
- Fixed small memory leak introduced in 2.0.996.0.
- Improved detection for VxWorks.
- New Office 2007 Theme. Settings -> Interface -> Theme Manager
- New VMS - Remove version from filename option in the Settings->Transfer->Files dialog.
- If the timeout is set to 0 in a favorite item it's automatically increased to 30s.
- Fixed: When extra long tooltips were used (e.g. German translation) for the buttons in some dialogs the application would crash.
- Fixed: The clipboard was emptied on exit.
- Fixed: Small problem in the Remote Tree Control which caused that the selection wasn't in sync with the view.
- Added "History" combo box to Remote Browser.
- Fixed: Problem with image list in "Favorites Window" if system color depth was lower than 32bit.
- File Exist Rules: Move Up/Down now possible.
- Fixed: Transfer Queue -> Upload Directory does now add the new items right below the item.
- Fixed: Transfer Queue -> Upload Directory no longer locks the enumerated directories.
- File Exist Rules: Added "Different" condition to Time and Size.
- Fixed: Disappearing cursor in the Remote Browser if the "Show window contens while dragging" system option is disabled.
- Remote Browser: Paste is now disabled if the data in the clipboard is from the same Remote Browser.
- Added support for MFMT
- Fixed: Small bug in File Exist Rules
- Fixed: Del key in filter control (ASCII, Exclusion, ...)
- Fixed: Data Connection Fail-over
- Pane layout is automatically reset after language is changed.
- Fixed: Timezone calculation
- New File Exist Rules
- Fixed: "Continue on Error" option for CHMOD.
- Added USER FireID@Host proxy type.
- Fixed: Transfer Speed Limits were broken.
- Fixed: URL Watcher didn't add the item correctly to Transfer Queue
- Fixed: Settings -> Transfer -> Performance settings didn't save.
- Extended speed control history to 512 seconds.
- Transfer Queue doesn't add items to the queue which match one of the exclusion filters.
- Fixed: Settings -> Transfer -> Compression "Exception List" didn't save.
- Fixed: Settings -> Interface -> Language control didn't show all modules.
- Edit Favorites window uses system images for folder icons.
- Fixed: Bug with double click in the Localbrowser's list control.
- Fixed: Clipboard problem in Terminal Sessions.
- Copy & Paste of favorite item into same folder works now.
- Transfer Queue: Improved saving/loading of queue file.
- Transfer Queue: Start of queue significantly improved if queue has a lot (10k) of items.
- "Don't save password on exit" option in Favorite Item -> General dialog.
- Login Dialog with "Update Favorite Item" option.
- Workaround for Microsoft FTP Server (IIS) if Cisco PIX firewall is installed with the ftp strict option enabled.
- Transfer Queue: Added hard limit (10000) for Sort Items.
- Fixed: Copy URL did cut off the last character
- Fixed: Transfer Queue: Reuse connection
- Fixed: MODE Z fallback
- Fixed: Wrong color in the log control (e.g. for FEAT reply)
- Fixed: "Update Check" shows download link to the correct platform (x86, x64) version.
- Added local file drop target to "Upload -> Select" dialog.
- Added Stop Time to Queue Timer Dialog
- Changed: History now longer remembers passwords. If passwords should not be saved use an empty password in the favorite item.
- Fixed: Quick Transfer toolbar setting
- Fixed: Protocol didn't save correct in Favorite Item dialog
- Fixed: File Monitor automatically restarts after the source path/file has been changed
- Fixed: Local Browser folder links do not longer open a new Windows Explorer instance
- Fixed: Fixed wait for retry bug in Transfer Queue
- Removed "Save Password" option in History settings. History only has references to the Favorites.
- Added new VxWorks parser type
- New "Quick Connect" dialog. File->New Remote Browser
- Changed format of Queue Items
- New control for "Exclusion List" and "ASCII List".
- Fixed: Incomplete URL or Host problem on Windows 9x.
- Replaced control in Priority List Global Settings with new one.
- Fixed: Compatibility problems with Windows 2000 and lower.
- Fixed: Windows->Auto Layout option wasn't always correctly saved
- New Time Zone settings for favorite item. If the LIST (instead of MLSD) command is used for directory listings the time will automatically adjusted according to the timezone setting in the favorie item.
- Fixed: Upload Dialog -> Add Files. Selection was limited to about 8 files
- New properties dialog for queue items.
- Fixed: Backspace in Remote Browser
- New "Monitor Local File" feature for queue items. Queue an item for upload then right-click on it and select "Schedule". Check the "Monitor Local File" checkbox click on OK. Start the Queue. Now everytime the local file changes it's been processed (uploaded).
- Translations < 2.0.994.0 are incompatible with this version and will crash the application if the "Schedule" dialog is opened.
- Optimized sorting of items
- Fixed: Navigation by keystroke
- "Priority List" in the Global Settings is automatically reset to the default.
- Proxy Exceptions and Selection Groups don't support regular expressions (regex) anymore
- Transfer Queue shows a warning in the log if there is insufficient space to transfer the complete file. Previously the transfer didn't start.
- Fixed: Edit Favorites window is now updated after a new favorite has been added using the "Add Favorite" dialog.
- Modifications affecting the Transfer Queue. Especially Thread per Site limit and Reuse Connection option.
- Fixed: Folder Up in "Edit Favorites"
- Fixed: Export in "Edit Favorites"
- Added sort for Remote Browser -> Bookmarks menu
- Fixed: Log Auto Hide/Restore problem
- Fixed: Rename bug in Favorites list control
- Fixed: Global accelerators (again).
- Added F6 to select address input box
- Added Add/Remove button in Settings->Transfer-Filters dialog.
- Removed unused string resources.
- Fixed: URLs (Help->Online Help, etc) didn't open when Maxthon was installed.
- Small performance improvements in the Local Browser Shell Tree control.
- Fixed: Problem on some systems where Drag&Drop from the Queue List Control to Windows Explorer would fail.
- Fixed: Global key accelerators didn't work when the Transfer Queue pane was focused
- Fixed: Tab didn't select the full text in the User input box in the address bar.
- Window/Pane state data now compressed when saved into the registry.
- Fixed: Settings were not saved if the Import Dialog was shown.
- Fixed: "Login to Proxy" didn't work correctly for several FTP Proxies (USER user@host:port, SITE, OPEN).
- Fixed: CHMOD didn't update current view.
- Fixed: When using the Queue Item Property Dialog, the username,password,port,host of the item wasn't updated.
- Added Drag&Drop from Queue List Control to Local Browser and Windows Explorer.
- Local Browser tree control is respecting the Windows Explorer "Hide protected operating system files" option.
- Disabled gradient in tool tips
- Replaced balloons with tool tips
- Last active tab is remembered on restore.
- Fixed: History option "Save Password" was not correctly saved.
- SmartHook.dll self-registers on every start of the application.
- Fixed: Proxy username not saved correctly.
- Fixed: Crash when the application is started with an URL in the command line: SmartFTP.exe ftp://test.com
- Fixed: Some custom commands including "RETR file". Commands sent with the "Command Line" are considered custom commands as well.
- Fixed: History is now saved regardless of the "Save History" option when the Settings dialog is closed.
- Fixed: Fixed a small bug which cause the Local Browser to refresh unexpectedly.
- Fixed: Right-click in tree control selected the item.
- Fixed: "Paste" in Local Browser.
- Added Copy&Paste to Remote Browser. When using "Paste" in the Local Browser use the toolbar or the "Commands" menu.
- Fixed: New Folder/New Favorite problem in "Edit Favorites" if the focus wasn't set.
- Fixed: "Statistics" window show/hide state wasn't saved in all cases.
- Changed Global Settings -> Queue : On Startup setting to be more flexible.
- Fixed: Global Settings dialog didn't notify other windows (e.g. Transfer Queue) of setting change.
- Support for z/VM servers.
- Removed gradient in "Quick Transfer" toolbar.
- Fixed: SmartHook.dll in 64bit build.
- Fixed: Drag&Drop to Desktop item.
- Rewrote importer for FlashFXP. Using MBCS now instead of Unicode.
- Changed: Selection Groups (Ctrl+0-9) not working in Local Browser if used shortkey
2.0.992.42 - 18. January 2006
- Fixed: Double click on SSL icon in status bar has no effect.
- New "Upload Dialog"
- New "Quick Transfer" Toolbar.
- Settings, Queue and other data is now saved when the computer is shutdown or the user is logged off while the application is running.
- Fixed: Remote Browser failed to restore the last selected folder.
- Fixed: Remote Browser view state (Windows Position in MDI mode, List Control columns, etc) is now saved into the registry instead of the favorite item.
- Fixed Logcontrol didn't set the world wrap correctly.
- Fixed: "Don't ask again" drawing glitch in the message box on systems with Large Fonts (120 dpi).
- Fixed: If the favorite item cannot be found (lost favorites.dat) the workspace manager restores a Remote Browser without connecting.
- Fixed "/s/s" in "Speed" window.
- Fixed: "New Folder" bug in the "Edit Favorites" window.
- Solution for problem described here: https://www.smartftp.com/forums/How-to-disa...html
- Fixed: Crash in Queue which has be caused if the application extracted the file size from the directory listing afer a failed SIZE command.
- Fixed: "USER Objects" resource leaks when opening/closing MDI windows.
- Added auto save of Queue every 5 minutes if an item has been added/remove/moved
2.0.992.34 - 12. January 2006
- Fixed: The Remote Browser didn't close properly when the Ident server was enabled on connect.
- Fixed: Some "GDI Object" memory leaks.
- Removed 8bit color bitmaps. 32bit alpha bitmaps are now re-sampled on OS not supporting alpha bitmaps (e.g. Windows 98).
- Small fixes on Windows 98.
- Fixed: Clicking on Go button the first time after startup has no effect.
- Import for FTPRush (RushSite.xml) sites. Passwords with more than 7 chars cannot be imported.
- Fixed: Problem if the Remote Browser was closed during the login sequence. e.g. after the PASS command.
- Fixed: Status Popup restore on startup.
- LIST a* does now work in the Command Line toolbar and in the Custom Commands.
- Remote Browser: Pane (Log, Command Line, Tree) states now serialized to registry.
- Tab Bar position can be set. Right-click on tab bar then select the "Position" sub menu.
- New travel log for Remote Browser.
- Fixed: Settings->Navigation "Double Click Action".
- Fixed: Favorites folder not automatically created if non existent.
- Fixed a problem with the spin controls in the Transfer Queue which has been introduced in .23.
- Remote Browser column details/order and windows position in the MDI mode are now correctly saved.
- Fixed a bug with the rename function in the ShellView control of the Local Browser.
- Fixed: View >> arrange icons >> by date >> does not work
- Ported some controls (Ask Command Argument dialog, Set Speed dialog, DateTime Dialog, Splash) to MFC.
- Fixed: Password input box in Favorites -> General dialog now shows the password in plaintext if the Global Settings -> Interface -> Show Password option is set.
- Added Backup Tool
- Fixed: History item is not added/moved to top if folder is cached.
- Fixed: Rename of current folder in tree caused the current location not to be updated correctly.
- Fixed: Icon of Update Check.
- Changed icon for "Local Browser" to the one in the menu: FTP->Local Browser
- Added Settings -> Backup dialog for automatic backup options.
- Workaround: Redraw problems in main window if "Close Remote Browser" user prompt is shown.
- Fixed: Missing icons in Local Browser combo box.
- Fixed: XTP: Drag over selection in CXTTreeCtrl is grey instead of blue?!.
- Fixed: Global Settings: History. Tool for Properties is "Properties / CHMOD" instead of "Properties"
- Fixed: History item (user/login) is not correct updated if changed.
- Fixed: Settings->Connection "Enable UPnP" option not correctly saved.
- TYPE I before SIZE.
- No more user prompts if the Global Queue "On Complete" action is set to "Close Application"
- Fixed: File Exist > Compare using a hash function for file exist action
- Fixed: High CPU usage when Global Queue is running.
- Fixed: File Exist settings are correctly saved.
- Fixed: Show Password option.
- Fixed: Global Speed Limits not set when changed in the Global Settings.
- Fixed: Applying filters to folders does not work.
- Scrolling text when minimized and transfer is in progress
- Fixed: Local Browser : Tree and Combo: Automatically seeks floppy drive.
- Added background color settings for log control
- Added "Login Dialog" if username or password is empty.
- Fixed shortcut keys in the list control inline edit control. (e.g. DEL would delete the item instead of the text selected)
- Fixed various font issues.
- Local Browser is now automatically opened on connect according to the Favorite Item settings.
- When connecting from the address bar, a new favorite item is automatically created if no matching item is found.
- Initial release for public
