Incompatible with the current KeePass version
Product page: KeePassRest Plugin
creativets
Post by creativets » Mon Feb 06, 2012 4:43 pm
I tried to setup Smartftp with KeePass, but it keeps saying that the plugin is incompatible with the current version..
My KeePass version is 2.18.
I hope you can help me.
Re: Incompatible with the current KeePass version
Post by mb » Mon Feb 06, 2012 11:02 pm
The keepassrest plugin is compatible with the latest version 2.18:
https://www.smartftp.com/keepassrest/
creativets
Post by creativets » Tue Feb 07, 2012 3:42 pm
I have installed the keepassrest plugin from the link you gave, but it keeps saying that the plugin is compatible with the current keepass version.
Post by mb » Tue Feb 07, 2012 8:04 pm
I just tested it on a fresh installation and it is working fine. Please contact support:
https://www.smartftp.com/support/kb/how ... f2653.html
Post by mb » Fri May 11, 2012 8:53 am
It turned out that Windows only comes with the client instead of the full profile of the .NET framework. The full profile can be installed from here:
.NET 4.6.2
