Frequent failed transfert of file
Edtech
Post by Edtech » Thu May 28, 2009 7:29 am
Hello,
I have frequent fail during file transfert with SmartFTP, it works perfectly with Filezilla.
I use Windows 7 x64 RC French and Nod32 4.0.424.0 (the reason is perhaps the AV, I don't know, but no problem with Filezilla).
Example :
[10:20:18] Resolving host name "ftp.xxx.fr"
[10:20:18] Connecting to [2001:x:x::x] Port: 21
[10:20:18] Connected to ftp.xxx.fr.
[10:20:18] 220 (vsFTPd 2.0.7)
[10:20:18] AUTH TLS
[10:20:18] 234 Proceed with negotiation.
[10:20:18] Connected. Exchanging encryption keys...
[10:20:19] Session Cipher: 168 bit 3DES
[10:20:19] TLS encrypted session established.
[10:20:19] Command channel protection set to Private.
[10:20:19] PBSZ 0
[10:20:19] 200 PBSZ set to 0.
[10:20:19] USER xxx
[10:20:19] 331 Please specify the password.
[10:20:19] PASS (hidden)
[10:20:19] 230 Login successful.
[10:20:19] SYST
[10:20:19] 215 UNIX Type: L8
[10:20:19] Detected Server Type: UNIX
[10:20:19] RTT: 66.611 ms
[10:20:19] FEAT
[10:20:19] 211-Features:
[10:20:19]  AUTH SSL
[10:20:19]  AUTH TLS
[10:20:19]  EPRT
[10:20:19]  EPSV
[10:20:19]  MDTM
[10:20:19]  PASV
[10:20:19]  PBSZ
[10:20:19]  PROT
[10:20:19]  REST STREAM
[10:20:19]  SIZE
[10:20:19]  TVFS
[10:20:19]  UTF8
[10:20:19] 211 End
[10:20:19] OPTS UTF8 ON
[10:20:19] 200 Always in UTF8 mode.
[10:20:19] PWD
[10:20:19] 257 "/"
[10:20:19] CWD /Releases/Sola Platinum
[10:20:19] 250 Directory successfully changed.
[10:20:19] PWD
[10:20:19] 257 "/Releases/Sola Platinum"
[10:20:19] TYPE I
[10:20:19] 200 Switching to Binary mode.
[10:20:19] SIZE [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:20:19] 213 265739840
[10:20:19] MDTM [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:20:20] 213 20090528024917
[10:20:20] PROT P
[10:20:20] 200 PROT now Private.
[10:20:20] EPSV
[10:20:20] 229 Entering Extended Passive Mode (|||63857|)
[10:20:20] Opening data connection to 2001:x:x::x Port: 63857
[10:20:20] RETR [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:20:20] Connected. Exchanging encryption keys...
[10:20:20] 150 Opening BINARY mode data connection for [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv (265739840 bytes).
[10:20:20] Session Cipher: 168 bit 3DES
[10:20:20] TLS encrypted session established.
[10:33:09] Transfer Timeout (60s). Closing data connection.
[10:33:09] 136380416 bytes transferred. (173 Ko/s) (00:12:48)
[10:33:09] 426 Failure writing network stream.
[10:33:09] MDTM [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:33:09] 213 20090528024917
[10:33:09] Transfer failed.
Here the transfert have failed without apparent reason : 426 Failure writing network stream.
[10:33:09] Resolving host name "ftp.xxx.fr"
[10:33:09] Connecting to [2001:x:x::x] Port: 21
[10:33:09] Connected to ftp.xxx.fr.
[10:33:09] 220 (vsFTPd 2.0.7)
[10:33:09] AUTH TLS
[10:33:09] 234 Proceed with negotiation.
[10:33:09] Connected. Exchanging encryption keys...
[10:33:09] Session Cipher: 168 bit 3DES
[10:33:09] TLS encrypted session established.
[10:33:09] Command channel protection set to Private.
[10:33:09] PBSZ 0
[10:33:10] 200 PBSZ set to 0.
[10:33:10] USER xxx
[10:33:10] 331 Please specify the password.
[10:33:10] PASS (hidden)
[10:33:10] 230 Login successful.
[10:33:10] SYST
[10:33:10] 215 UNIX Type: L8
[10:33:10] Detected Server Type: UNIX
[10:33:10] RTT: 67.739 ms
[10:33:10] FEAT
[10:33:10] 211-Features:
[10:33:10]  AUTH SSL
[10:33:10]  AUTH TLS
[10:33:10]  EPRT
[10:33:10]  EPSV
[10:33:10]  MDTM
[10:33:10]  PASV
[10:33:10]  PBSZ
[10:33:10]  PROT
[10:33:10]  REST STREAM
[10:33:10]  SIZE
[10:33:10]  TVFS
[10:33:10]  UTF8
[10:33:10] 211 End
[10:33:10] OPTS UTF8 ON
[10:33:10] 200 Always in UTF8 mode.
[10:33:10] PWD
[10:33:10] 257 "/"
[10:33:10] CWD /Releases/Sola Platinum
[10:33:10] 250 Directory successfully changed.
[10:33:10] PWD
[10:33:10] 257 "/Releases/Sola Platinum"
[10:33:10] TYPE I
[10:33:10] 200 Switching to Binary mode.
[10:33:10] SIZE [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:33:10] 213 265739840
[10:33:10] MDTM [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:33:10] 213 20090528024917
[10:33:10] Source File: Size=265739840, SizeUnit=Byte, Time=2009-05-28T02:49:17, TimeFormat=Exact
[10:33:10] Destination File: Size=136380416, SizeUnit=Byte, Time=2009-05-28T02:49:17, TimeFormat=Exact
[10:33:10] RecentTime=2009-05-28T08:33:09
[10:33:10] Rule "IF Destination Time=Equal AND Size=Smaller AND Transfer=No Matter THEN Resume" matched. Action="Resume".
[10:33:10] PROT P
[10:33:10] 200 PROT now Private.
[10:33:10] EPSV
[10:33:10] 229 Entering Extended Passive Mode (|||44759|)
[10:33:10] Opening data connection to 2001:x:x::x Port: 44759
[10:33:10] REST 136380416
[10:33:11] Connected. Exchanging encryption keys...
[10:33:11] 350 Restart position accepted (136380416).
[10:33:11] RETR [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:33:11] 150 Opening BINARY mode data connection for [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv (265739840 bytes).
[10:33:11] Session Cipher: 168 bit 3DES
[10:33:11] TLS encrypted session established.
[10:38:20] Transfer Timeout (60s). Closing data connection.
[10:38:20] 47087616 bytes transferred. (148 Ko/s) (00:05:09)
[10:38:20] 426 Failure writing network stream.
[10:38:20] MDTM [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:38:20] 213 20090528024917
[10:38:20] Transfer failed.
Same things her : 426 Failure writing network stream.
[10:38:21] Resolving host name "ftp.xxx.fr"
[10:38:21] Connecting to [2001:x:x::x] Port: 21
[10:38:21] Connected to ftp.xxx.fr.
[10:38:21] 220 (vsFTPd 2.0.7)
[10:38:21] AUTH TLS
[10:38:21] 234 Proceed with negotiation.
[10:38:21] Connected. Exchanging encryption keys...
[10:38:21] Session Cipher: 168 bit 3DES
[10:38:21] TLS encrypted session established.
[10:38:21] Command channel protection set to Private.
[10:38:21] PBSZ 0
[10:38:21] 200 PBSZ set to 0.
[10:38:21] USER xxx
[10:38:21] 331 Please specify the password.
[10:38:21] PASS (hidden)
[10:38:21] 230 Login successful.
[10:38:21] SYST
[10:38:21] 215 UNIX Type: L8
[10:38:21] Detected Server Type: UNIX
[10:38:21] RTT: 66.625 ms
[10:38:21] FEAT
[10:38:21] 211-Features:
[10:38:21]  AUTH SSL
[10:38:21]  AUTH TLS
[10:38:21]  EPRT
[10:38:21]  EPSV
[10:38:21]  MDTM
[10:38:21]  PASV
[10:38:21]  PBSZ
[10:38:21]  PROT
[10:38:21]  REST STREAM
[10:38:21]  SIZE
[10:38:21]  TVFS
[10:38:21]  UTF8
[10:38:21] 211 End
[10:38:21] OPTS UTF8 ON
[10:38:21] 200 Always in UTF8 mode.
[10:38:21] PWD
[10:38:21] 257 "/"
[10:38:21] CWD /Releases/Sola Platinum
[10:38:22] 250 Directory successfully changed.
[10:38:22] PWD
[10:38:22] 257 "/Releases/Sola Platinum"
[10:38:22] TYPE I
[10:38:22] 200 Switching to Binary mode.
[10:38:22] SIZE [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:38:22] 213 265739840
[10:38:22] MDTM [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:38:22] 213 20090528024917
[10:38:22] Source File: Size=265739840, SizeUnit=Byte, Time=2009-05-28T02:49:17, TimeFormat=Exact
[10:38:22] Destination File: Size=183468032, SizeUnit=Byte, Time=2009-05-28T02:49:17, TimeFormat=Exact
[10:38:22] RecentTime=2009-05-28T08:38:20
[10:38:22] Rule "IF Destination Time=Equal AND Size=Smaller AND Transfer=No Matter THEN Resume" matched. Action="Resume".
[10:38:22] PROT P
[10:38:22] 200 PROT now Private.
[10:38:22] EPSV
[10:38:22] 229 Entering Extended Passive Mode (|||41927|)
[10:38:22] Opening data connection to 2001:x:x::x Port: 41927
[10:38:22] REST 183468032
[10:38:22] Connected. Exchanging encryption keys...
[10:38:22] 350 Restart position accepted (183468032).
[10:38:22] RETR [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv
[10:38:22] 150 Opening BINARY mode data connection for [M-F]Sola_05_(1280x720_H264-MP3)_ [6506536B].mkv (265739840 bytes).
[10:38:22] Session Cipher: 168 bit 3DES
[10:38:22] TLS encrypted session established.
Re: Frequent failed transfert of file
Post by mb » Thu May 28, 2009 2:39 pm
Post the log from FileZilla.
Please also check the debug log from vsftpd since it's the party that believes that there is a problem.
Post by mb » Thu May 28, 2009 6:34 pm
Please also retry it with the latest version of vsftpd. A couple of SSL/TLS related bugs have been fixed according to their changelog.
Edtech
Post by Edtech » Wed Jun 17, 2009 9:26 am
Ok, I can't try before a new version in my distribution.
Sorry for the long time between my first post and this answer.
