Director Listing Problem
jfm
Post by jfm » Fri May 15, 2009 8:56 am
I am currently using smartFtp version
v3.0 Build 1027.5 13. May 2009
and when smartFtp tries to do a listing with a directory wit a strange problem. The directory name is
The Invaders Part 3 (of 3) Season 2 E 15 - 26, Doppelgänger
and what is showing up in the directory listing is
The Invaders Part 3 (of 3) Season 2 E 15 - 26, Doppelg?drwxr-xr-x 2 admin administrators 4096 May 5 20:42 The Invaders[Season 1][1967]DvDrip[Eng]-McParts
It looks as if it has appended the rest of the 'ls' command and the next directory name th this one. The next directory
does not show up in the list.
Regards
John Martin
Re: Director Listing Problem
Post by mb » Fri May 15, 2009 9:09 am
Hello John ..
Can you send us the raw directory listing to support@smartftp.com?
To get the raw directory listing, right-click on the folder and then select "Show Raw Listing" from the context menu.
jfm
Post by jfm » Fri May 15, 2009 11:02 am
Hello John ..
The raw listing is
drwxrwxrwx 7 admin administrators 4096 May 15 15:48 .
drwxrwxrwx 6 admin administrators 4096 Apr 13 12:42 ..
drwxr-xr-x 2 admin administrators 4096 May 12 22:22 The Invaders Part 2 (of 3) Season 2 E 1 - 14
drwxr-xr-x 2 admin administrators 4096 May 12 22:23 The Invaders Part 3 (of 3) Season 2 E 15 - 26, Doppelg?drwxr-xr-x 2 admin administrators 4096 May 5 20:42 The Invaders Season 1
drwxr-xr-x 2 admin administrators 4096 May 15 15:48 a MOMENT in june
Does that mean it is coming from the server like that.
john...
Post by mb » Fri May 15, 2009 11:06 am
Yep it looks like the bug is with the server.
jfm
Post by jfm » Fri May 15, 2009 11:15 am
OK, thanks for that. I didn't even know that 'Show Raw Listing' option was there. Anyway I changed the option CharsetRemote in the proftpd server from ASCII to UTF-8 and all is OK.
Thanks, john...
