Error with extension
Edtech
Post by Edtech » Fri Feb 13, 2009 6:52 pm
Hello !
When you upload a file under Windows 7 (build 7000, x64), the extension is not always correctly read, and the file uploaded don't have extension.
Re: Error with extension
Post by mb » Fri Feb 13, 2009 6:57 pm
I don't understand your problem. Can you please explain?
Please install the latest beta version:
Edtech
Post by Edtech » Sun Feb 15, 2009 6:24 pm
If I upload "toto.txt", the file create on the server is only "toto", the ".txt" extension has dispear. But it's not always. It occurs if the extension is knew by the operating system. If Windows don't know the extension, the file is correctly named on the sever. I try to activate the displaying of the extension in the explorer, but this don't resolve the problem.
SmartFTP fail to test the existence of a file because it compare "toto" with "toto.txt" and don't found the correct file.
I have the 3.0.1026.2, but I was the same bug with the current stable version.
Post by mb » Sun Feb 15, 2009 10:44 pm
This problem only occurs on Windows 7?
Edtech
Post by Edtech » Sat Feb 21, 2009 8:47 am
This problem existed under Windows Vista but was corrected. Now, it's only with Windows 7.
Post by mb » Sat Feb 21, 2009 4:05 pm
I'm unable to reproduce the problem with Windows 7 Build 7000.
Edtech
Post by Edtech » Mon Feb 23, 2009 11:45 am
Perhaps only with the x64 version ? I use SmartFTP in x64.
Edtech
Post by Edtech » Thu Mar 05, 2009 9:51 am
I have installed the build 7048 of Windows 7, and the bug have disapeared...
Post by mb » Thu Mar 05, 2009 9:18 pm
Good to know ;-) Thanks for the feedback.
